Ae86 need help
KSIGRIM
Ae86 need help
Postby KSIGRIM » Thu Apr 09, 2015 9:44 pm
I have a 1986 Toyota corrola coupe I have a problem with it it keeps bogging out on me idk what's wrong with it. I ll have it on and then out of no where the rpms drop and it dies out. Any ideas?
jinx
Re: Ae86 need help
Postby jinx » Thu Apr 09, 2015 11:54 pm
4AC ? need more info
Re: Ae86 need help
Postby MisterJerk » Fri Apr 10, 2015 6:17 am
dude!.. download the manual.
in my sig.
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Fri Apr 10, 2015 10:43 pm
Jinx it's the motor it will turn on but it dies out after a bit like it Boggs out and lose power
allencr
Re: Ae86 need help
Postby allencr » Sat Apr 11, 2015 12:31 am
KSIGRIM wrote:Jinx it's the motor it will turn on but it dies out after a bit like it Boggs out and lose power
There you go Jinx, it's the motor!
Good luck. :roll:
Re: Ae86 need help
Postby totta crolla » Sat Apr 11, 2015 2:13 am
There are a thousand a one things that could be wrong and if doing a diagnostic test as per the manual and posting the results on here is beyond your capability then you should waste no time, yours or ours, in taking the car to someone who can fix it for you.
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Sat Apr 11, 2015 5:21 pm
Where would the Camshaft Position Sensor be located at?
Re: Ae86 need help
Postby jondee86 » Sat Apr 11, 2015 9:55 pm
If you have a GTS the camshaft sensor is inside the base of the
distributor. There should be one 4-tooth wheel which is the crank
angle sensor, and one 1-tooth wheel on top which is the reset or
cam sensor. Like this...
The pickups are the black bits with wires coming out of them.
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Sun Apr 12, 2015 12:41 am
I did sure for it but wasn't sure if that was it Cuz difrent location poped out
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Sun Apr 12, 2015 12:43 am
Thank u. So if that sensor was messed up would u have to replace the whole distributor?
Re: Ae86 need help
Postby jondee86 » Sun Apr 12, 2015 3:00 am
I don't know if you can buy the pickups separately... probably not unless
you could find a place that rebuilds distributors. But you could swap the part
from another dissy if you picked up the exact same dissy from a junkyard.
If you do that you need to set the gap between the tip of the teeth on the
wheel and the face of the sensor. Use feeler gauges... the gap should be
0.2 to 0.4mm (0.008 to 0.016").
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Sun Apr 12, 2015 10:42 am
Oh Ight thank u
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Wed Apr 15, 2015 9:50 pm
Ok so I read my engine it marked that my camshafted position sensor was bad so I bought a new distributor and I marked where the timing was set at before I took it off I put the new one same way and I put it in and I use a timing gun and it marked it wrong but the thing was I cant find my Diagnostic port to put the ecu in safty mode. I looked it up and it show a black box but I tryed looking for it on my car and that black box wasn't there
Re: Ae86 need help
Postby jondee86 » Wed Apr 15, 2015 10:54 pm
Read this first to make sure you have the dissy installed right...
AE86 16V - Installing Distributor - DIY
If you can't find the diagnostic box (late model AE86) or the round yellow
two-pin diagnostic plug (early model AE86)... don't worry :) You can still
time the engine near enough.
Step 1. Mark the timing notch on the rear rim of the crank pulley with some
white paint, Tip-Ex or similar. Put a dab of paint on the 15 degree mark on the
scale embossed onto the lower timing belt cover.
Step 2. Get the engine idling at 850-900rpm. You can adjust the idle speed
by turning the air screw that is down the tube on the side of the throttlebody.
Step 3. Hook up your timing light to the #1 spark plug lead, and shine the light
down towards the timing marks. Loosen up the bolts holding the dissy and twist
the dissy forward and back a little. See which way the mark on the pulley moves.
Step 4. Move the pulley mark until it is a little to the left of the 15 deg mark,
around 16-17 deg is good. Tighten up the bolts... job done :)
KSIGRIM
Re: Ae86 need help
Postby KSIGRIM » Thu Apr 16, 2015 5:07 pm
Ok thanks I ll let u no how it turns out
