Core/freeze plug size
PDB
Postby PDB » Thu Feb 12, 2015 10:04 am
Had a google but no luck and don't want to take the manifold off to measure it.
Anyone know what size the core/freeze plug is above the starter motor please.
Mines just started to weap :(
jdm86gtz
Re: Core/freeze plug size
Postby jdm86gtz » Thu Feb 12, 2015 3:28 pm
The EPC shows the small size is 35mm (5 in the block) and the 1 bigger sized plug is 40mm.
So on the exhaust side there's a 40mm plug beside cyl 3 and a 35mm plug by cyl 4.
PDB
Postby PDB » Fri Feb 13, 2015 5:10 am
Thanks, it's the 40mm one that's gone.
PDB
Postby PDB » Sat Feb 14, 2015 7:01 am
Tiny hole at the end of the blade, makes me wish I had replaced them all when I had the engine out and in bits :(
Rogue-AE95
Postby Rogue-AE95 » Sat Feb 14, 2015 11:13 pm
The OEM ones are steel? I thought I saw pics of freeze plugs that looked like brass. Aftermarket maybe?
'88 Corolla All-Trac
PDB
Postby PDB » Sun Feb 15, 2015 7:36 am
I think most are zinc plated. My engine sat for 15 years before I got hold of it hence the poor condition of the plugs.
Even the timing belt tensioner was seized solid, all the grease had gone where is had sat for so long.
Most engines won't be like this.
