Bilstein Universal Inverted Strut
Nativo
Postby Nativo » Mon Jan 19, 2015 11:25 am
Has anyone build a front suspension using Bilstein Universal Inverted 46mm struts? IFAIK those are the best, most affordable and rebuildable struts in the market.
Re: Bilstein Universal Inverted Strut
Postby Deuce Cam » Mon Jan 19, 2015 4:12 pm
That's a great idea. Their description says the O.D. of the strut tube is 50 mm. I'm happy to report that the O.D. of the oem ae86 strut tube is basically the same size. Considering this it might be possible to use stock ae86 spindles and even cup weld them the proper way (assuming the Bilstein strut is steel). Also, it looks like one has to machine the end that the camber plate/top bushing attaches to. Unfortunately, I couldn't find the overall dimensions for these units.
Postby MisterJerk » Tue Jan 20, 2015 6:54 am
i want them to be threaded all the way, so can change out the ones in my coilovers
Nativo
Postby Nativo » Tue Jan 20, 2015 2:10 pm
Al that is needed is different lengths springs for whatever use you might have
Nativo
Postby Nativo » Thu Jan 22, 2015 5:47 am
Deuce Cam wrote:That's a great idea. Their description says the O.D. of the strut tube is 50 mm. I'm happy to report that the O.D. of the oem ae86 strut tube is basically the same size. Considering this it might be possible to use stock ae86 spindles and even cup weld them the proper way (assuming the Bilstein strut is steel). Also, it looks like one has to machine the end that the camber plate/top bushing attaches to. Unfortunately, I couldn't find the overall dimensions for these units.
Here you go;
http://streetwiseparts.com/collections/bilstein/products/bilstein-universal-motorsports-strut-46mm
Nativo
Postby Nativo » Wed Jan 28, 2015 10:57 am
Anyone knows our car's strut's nut size and thread pitch?
