Wanted To Buy; AE92 Smallport Misc Parts
egjoe
Postby egjoe » Sun Oct 19, 2014 10:34 pm
Updated list as of 02/28/15
I just need an AE92 Small port Engine Harness.
pm me back with what you have. Im here in So.California.
Thank you
Kilo
Re: Wanted To Buy; AE92 Smallport Misc Parts
Postby Kilo » Thu Feb 26, 2015 11:20 pm
I have a spare distributor that can come with the following:
- heat shield
- distributor cap
- 2 x KBox 12311973 Seal Repair Kits (one kit brand new unused and the other kit has been opened to be used on the spare distributor for just the bearing, while all other rubber seals are still brand new)
- NGK wire set, brand new unused
I'm not too sure whether I still have a spare ignitor with coil or not... I can go searching if serious.
I also have a spare ECU lying around somewhere, I'll hafta dig it out sometime.
The harness is all cut up and is a mess... I intend to save it to sell with my spare engine... how badly do you need it?
All parts are off from an AE92 1990 Corolla GT-S.
E-mail me at temporarykilo@hotmail.com as I do not frequent theses forums. List the items you're interested in and throw me a price (I can then take pictures for you, just remind me). I'll decide to let them go or not.
Just remember that I'm located in Vancouver, BC, Canada, so shipping maybe a bit more expensive compared to shipping within the US.
Joe4ag
Postby Joe4ag » Sat Feb 28, 2015 5:00 pm
Hello, I have the ecu and distributor if intesrested you canText me at 681.484.two six one nine
ae82hybrid
Postby ae82hybrid » Sat Feb 28, 2015 6:49 pm
Are you looking for spare parts for the Cali version or Fed version of the smallport, there is a difference in the two versions. For example the Cali version uses a secondary o2 sensor and EGR temp sensor, the Fed doesn't and the harness won't have connectors for it. So if running the Cali ECU on Fed harness you will have a CEL.
egjoe
Postby egjoe » Sat Feb 28, 2015 11:09 pm
Thanks for the info, I only need the harness, either California or 49 states will do.
ae82hybrid wrote:Are you looking for spare parts for the Cali version or Fed version of the smallport, there is a difference in the two versions. For example the Cali version uses a secondary o2 sensor and EGR temp sensor, the Fed doesn't and the harness won't have connectors for it. So if running the Cali ECU on Fed harness you will have a CEL.
Return to “Want to BUY (seeking sellers)”
