3sgte swap need help
theshaw0000
Postby theshaw0000 » Sun Jan 20, 2013 9:45 am
What all will i need to do this if anyone has a full write up or a parts list that wu be awesome
tercelica
Re: 3sgte swap need help
Postby tercelica » Mon Jan 21, 2013 11:43 pm
I have a 3SGTE RWD swap on a 75 Celica. Takes a lot of time and bling(if your a broke as$paragus like me)
Here is the basics of what I have for it to be RWD. There is a lot more other stuff but I think these are the Main parts for the RWD. I got most of my RWD conversion info from Toymods.
-3rd Gen 3SGTE
-2S bellhousing on a W58 Transmission. But you need to mill 5mm from the Bell housing for the input shaft to be far enough in (also look up a 4Y Bellhousing)
-2s pan and oil pump
-Custom motor mounts (I have a set of 2s which works too, but I made my motor mounts so I could use the Megan AE86 Mounts)
-Custom Front Facing Intake Manifold (I've seen some people do their RWD conversion without a FFIM)
-Custom Turbo Manifold with a Turbonetics T04E
Old Pic
tofufoo
Postby tofufoo » Tue Feb 05, 2013 4:03 pm
@ tercelica hi. I'm doing the same swap. With 2nd gen. I have the bellhousing with starter on the left handside. I was wondering what starter, flywheel, clutch, fork, bearing did you use? There was an old post on the old 4age forum but I guess they took it out.
kuroki86
Postby kuroki86 » Tue Feb 05, 2013 8:42 pm
pretty expensive swap in an 86. have you considered sr20 swapping it or did you want to stay toy?
