4AFE vs 4AGE Oil Pump
chi-town
Re: 4AFE vs 4AGE Oil Pump
Postby chi-town » Mon Aug 12, 2013 5:53 pm
You guys know this could easily be put to rest with some basic measurements. Take a factory pump and an Aisin pump and measure the gears, the bore in the housing, and the clearances. If you have more than one pump laying around measure both. This speculation and guessing isn't providing any one with usable information.
OST- I've had multiple bad Toyota pumps right out of the box, I now go through every one I use and check specs. You would be surprised how many don't spec out.
ChakaRaka
Postby ChakaRaka » Thu Aug 22, 2013 8:25 pm
Well here are the photos of the two pumps side by side.
Left is Aisin OPT-32 AKA 15100-15060 (Aisin casting: "Aisin 10". Right is Aisin OPT-36 AKA 15100-19036 (Aisin casting: "Aisin 2". And yes the seal is installed in the one on the right. Note also the gear thickness difference in the last photo.
So there were the photos I said I'd post. I did not have time to take measurements off everything but I thought some visuals might help.
Postby oldeskewltoy » Fri Aug 23, 2013 8:23 am
oldeskewltoy wrote:Reason to buy ONLY OEM.......
Aisin housings can be bored to different depths.... shallower depth = similar pressure... less volume... but maybe... enough volume. Material the pump gears are made from. One material for Toyota... another might be good enough...
When you pump THOUSANDS of dollars into an engine.... buying crap aftermarket for a crucial part... just doesn't make sense.
Those gears do not look like they are made from the same material.....
ChakaRaka wrote:Image
What would be interesting... is to now get a Toyota 19036 pump and disassemble it, and then compare depths, and material...........
Rogue-AE95
Postby Rogue-AE95 » Fri Aug 23, 2013 5:46 pm
ChakaRaka wrote:Left is Aisin OPT-32 AKA 15100-15060 (Aisin casting: "Aisin 10".
The one on the left is definitely for a 4A-FE (at least, an '88-'92 4A-FE). Here's a pic of my CAT wagon's 4A-FE oil pump:
ChakaRaka
Postby ChakaRaka » Fri Aug 23, 2013 6:15 pm
Actually it is supposed to be a 93-95 Corolla 4A-FE from my reference.
ChakaRaka
Postby ChakaRaka » Fri Sep 06, 2013 6:57 am
Not the two parts engines I have. Why would that make any sense? The have piston squirters, so should require the higher volume pump...
apsogosGTi
Postby apsogosGTi » Fri Sep 06, 2013 12:58 pm
i think the oil pump spring makes the difference in pressure...correct me if i am wrong
Postby yoshimitsuspeed » Fri Sep 06, 2013 3:51 pm
apsogosGTi wrote:i think the oil pump spring makes the difference in pressure...correct me if i am wrong
The spring limits pressure but the pump has to produce enough volume at that pressure before the bypass spring even opens. If the pump is too small then it won't make enough pressure to open the bypass.
