FS 4age big port head 20v block and other parts
i have for sale my project i started. 20v block, crank, HKS stroker crank, rods, big port head. 20v throttles bodies with adapter plate, 20v plenum adapter and plenum. toda 264 cams. i would like to sell the whole lot for 2500$ block is perfect still use standard bore. plenum adapter is SQ engineering. plenum is nissan pulsar gtir that was worked, cleaned and polished. cams have no miles on them.both cranks are good no machining needed. I can send pictures
quietskaterguy
Eightysixer23
Re: FS 4age big port head 20v block and other parts
Willing to sell just the cams?
mr2mk1hero
Interested in selling just the cams?
If not, Can you ship the whole thing internationally?
Are you interested in other parts? I can ship internationaly
mr2mk1hero
What are the conrods?
Maybe even the stroker crank....if I can fit it into a 7rib bigport block? Is it good for a mild NA build? what other mods would it need?
The HKS stroker kit has the crank and rods and pistons. pistons are bad so it will need new ones and bearings. it will fit in any 4age block. may need to modify block. will add more torque.
mr2mk1hero
Do you have valve springs to go along with the cams?
no valve springs
