Need advice on coolant passage corrosion!!!!!!!
benjamingon
Postby benjamingon » Sat Nov 22, 2014 2:24 pm
the culprit :
so all you members with more experience, Im just wondering is this too much corrosion around the coolant ports? should i just find a replacement
allencr
Re: Need advice on coolant passage corrosion!!!!!!!
Postby allencr » Sun Nov 23, 2014 7:45 am
The head and block absolutely NEED a clean&smooth&flat unpitted surface, machined, but only on that circle that the gasket's fire-ring sits on, about 3-4mm wide around the cylinder that they mate against.
Anything else is very secondary but does have to deal with some pressure, like the cams oil feed 70psi, coolant 20psi and the vent/oil drain with crankcase pressure/blowby, so a light smear of gasket cement/sealer can take care of them when the surfaces are marginal. If a few or more mm machined off won't fix the fire-ring area, it'll need to be heliarced/welded.
Yours looks like it'll cleanup with a sanding block & emery or wet&dry. Got a piece of very flat hardwood or a piece of marble from a trophy base or granite tombstone?
benjamingon
Postby benjamingon » Sun Nov 23, 2014 12:11 pm
Thanks I just thought of jb welding some of it and having it machined, thanks for the input and advice allencr
allencr
Postby allencr » Sun Nov 23, 2014 9:38 pm
Nothing needs JB, the combustion chamber NEEDS metal ->gasket->metal, everything else but the pressurized oil port is fine with any gasket cement. RTV is NOT gasket cement.
Just scrape most of the corrosion outa the coolant ports, I doubt its extra surface area transfers heat better.
benjamingon
Postby benjamingon » Mon Nov 24, 2014 12:35 pm
not removing anything from the combustion area just wanted to add it to the corroded area of the water jacket
Postby oldeskewltoy » Wed Nov 26, 2014 9:34 am
Have the head cleaned, and pressure checked... if it cleans up and checks out ok... leave the pitting as it is.... **IF** the JB Weld comes free, it'll likely clog up part of the cooling system.
If you can get a hold of another head in better condition.... yes it likely is a better place to start from
allencr
Postby allencr » Wed Nov 26, 2014 10:55 am
Why is it apart, any reason to suspect that it is cracked from a really serious overheating meltdown, you're unable to clean it up yourself, something, otherwise you can clean it & skip any pressure and/or hardness and/or whatever test? DD or race or OEM rebuilt to last another 20+ years as a DD?
benjamingon
Postby benjamingon » Wed Feb 18, 2015 5:15 pm
this is gonna be a daily but id get it tig welded, machined, but im gonna find a head in better condition, thanks allencr and oldskewltoy always nice to hear from guys with tons of knowledge and experience
