I am at present building a small lightweight Hotrod/streetrod, it was going to be Bike powered front engine RWD, but I was offered a deal on a stash of 4AGE 16v engines and RWD parts, including a T50, It took all of about 30 seconds to say YES, one engines is from a AE86s and 2 are MR2, other bits include 40DHLAs and manifold-----
The car is going to be, I hope be retro in style, hence, Where I want to go with the engine, one of the things I want to do is lose the serpentine belt and retrofit a V belt drive, use a small denso alternator inside a old Lucas Dynamo case etc,
I will cast an alloy front cover so I can direct drive a distributor off the end of the cam, the distributor has a drive off of it so I can run a chronomatic mechanical tach, internals of the dissy will probably running a 36-1 disc inside it running an optical trigger and mapped 3d ignition.
My first question, (there probably will be loads more) -------- is there a bolt on pulley that I can fit to remove the serpentine belt system and go to V belt, from an early engine??
As my car will possibly weigh in under 350kg, 800lbs, I was thinking of a lightened flywheel too, where is the best place to shed weight from it, and how much, can I expect to lose from it, Im guessing by removing some of the "pot", I have no desire to run a paddle or multiplate clutch, any other suggestions about the flywheel??
many thanks
Ian
