Sr20det into ae86 Gauge cluster problem
ae86sr20de
Re: Sr20det into ae86 Gauge cluster problem
Postby ae86sr20de » Tue Dec 24, 2013 12:24 pm
Well for the Tach you need this converter box to convert the signal. The speedo I have tried 3 different speedo gears but still nothing. making something is wrong w/ my cluster or cable or I'm just not using the correct speedo gear?
I'm curious how u got your temp to work? I had to put a tube of aluminum between the radiator hose & welded a bung to fit the stock 4age toyota temp sensor & then wired it in.
Engmus
Postby Engmus » Fri Dec 27, 2013 7:09 pm
I've read that 280zx speedo cable will work.
