FS: Rebuilt 4AG hi-comp motor
Hi everyone. I'm selling a newly rebuilt 4AG motor with 0 miles and the specs are below. The engine is located in Van Nuys, CA, no shipping at this time. Asking $1800 and you can contact me at OSanchez1026@GMail.com.
High-comp bottom end
-new freeze plugs
-honed
-new rings
-new bearings
-comes with oil pump
Large port head
-3 angle valve job
-new seals
-shims replaced as needed
-new freeze plugs
-honed
-new rings
-new bearings
Large port head
-3 angle valve job
-new seals
Re: FS: Rebuilt 4AG hi-comp motor
Large Port ≠ high comp.
You got yourself a low comp there my friend high comps are small ports.
It's a custom setup. Hybrid
Hi comp block with big port.
Look at the return line on the block
I had this setup before. It's awsome with 72 cams
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
PMs and emails responded.
Up there!
PMs and e-mails replied. Bump!
Friday bumpage!
This was my original plan for my bigport... decided for 20v instead. Glws man!
All e-mails responded.
New price: $1400.
Thanks for the e-mails and calls yesterday, guys. As I mentioned, the engine comes with a 1 year warranty from the builder! Let's get this sold before Christmas!
Sorry for this stupid question. Been having problems finding a smog hook up on my Corolla. I honestly dont know much about the 4ag motors. Will this motor pass smog? Im getting tired of trying to smog my AE86 with SR20 swap. Thinking about going back to stock. So I can drive my car again.
Hmmmm I might consider this n just swap my cams, underbucket shim n carbs...how far r u from SD? I just arrived on west coast so still learning
Thanks for the emails and inquiries.
AE86SR20
This is a direct drop in and will pass visual and smog as long as you have all of your smog equipment installed. I have the same setup in my coupe and recently passed the new Star Smog tests.
DrAE86Toreno
The engine is located in zip code 91406, Van Nuys, CA.
AE86SR20
DrAE86Toreno
This seller is the real deal so if you need a great engine buy this one !
hmm 2 hrs plus...not bad...ill email you in the next few days or so
How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
DrAE86Toreno wrote:How is this type of engine setup? U say you have it on your coupe...is it pretty good? If I get it I'll b adding toda 288 w/ 10.5 lift ...underbucket shims n mikuni 44...I'd just like a nice street setup to have fun with
The hicomp bottom is a vast improvement and the engine response is very noticeable. Your set up is NOT good for street as the 44 Mikunis are too large and your choice in cams is too aggressive. You won't get the bottom end response and useable power at the low end that you need for street use and will be a dog to drive, trust me on this. For street, I strongly recommend you go with 40mm Webber carbs and less aggressive cams, around 262 w/8mm lift like HKS, Toda Poncams, Web, or Colt.
Your set up, with my hicomp engine, is better suited for track use where top end response and power matters more. You won't have any fun on the streets with the set up you called out as it will most likely bog off the start, unless you rev it really, really high, which will probably burn your clutch.
Gotcha...yeah I'm pretty much running what I described...I dnt make power until 4k to above...i don't drive the car everyday so I don't mind I just need a new motor or either rebuild mine...I'm not trying to spend on new cams n carb setup that's y...moving to Japan in a year so just trying to do a quick rebuild...I'll hit u up soon hopefully motor still available
Engine is sold!
