4ag2 20V: how to tuck or hide throttle cable?
Gabriel82
Postby Gabriel82 » Mon Aug 12, 2013 1:05 pm
Anyone know how to do this? Thoughts? Thanks.
morgan
Re: 4ag2 20V: how to tuck or hide throttle cable?
Postby morgan » Mon Aug 12, 2013 5:40 pm
Youre still trying to figure this out?!
Pave the way and be the first to adapt a throttle-by-wire to the motor. After all this time with no answer, you might as well step up.
My turd of an 86
20v swapped 86 write-up
Gabriel82
Postby Gabriel82 » Tue Aug 13, 2013 8:25 am
lol true..
hmm here's a thought...
wireless throttle?
too much?
morgan
Postby morgan » Tue Aug 13, 2013 8:48 am
use the Force, Luke...
My turd of an 86
taroroot
Postby taroroot » Thu Aug 15, 2013 8:41 pm
Gabriel82 wrote:lol true..
wireless throttle?
too much?
Judging by how many dropped calls I get, how badly my GoPro Wifi works, etc I would not trust to go wireless throttle!
Gabriel82
Postby Gabriel82 » Thu Aug 15, 2013 9:54 pm
Are there cars/motorcycles that have thing kinda set up?
choi0706
Postby choi0706 » Sun Aug 18, 2013 7:18 pm
why? only way is to use a dbw setup.. plus u need an ecu to control it..
Postby yoshimitsuspeed » Sun Aug 18, 2013 7:43 pm
On my AW11 I had just enough cable to tuck it under the spark plug cover. I made a bigger notch in the cover where the VVT wire feeds over the valve cover and opened up the other end a little bit to get a decent angle where it hooks to the ITBs. It's a little tight but it did work. If you are FF or FR it may not help you as much. On FR though you might be able to run it just above the header pretty out of sight then under the spark plug cover.
gaijin_rokurunner
Postby gaijin_rokurunner » Tue Aug 20, 2013 5:14 pm
you need something like this to get rid of the stock linkage and u can run the throttle cable behind the engine up under the ITBs to this new linkage below.
