What did you do to your car today?
Be nice to others.
KonaTrueno723
Re: What did you do to your car today?
Postby KonaTrueno723 » Wed May 01, 2013 10:04 pm
^^^Man that must've been an "OH' :shock: SH*T" moment! But seriously,route them suckers away
For my car today,,i installed my new LHD TRD floor mats
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
carbd7age
Postby carbd7age » Thu May 02, 2013 4:31 am
A buddy of mine brought his Civic to me at work, it was misfiring. He said he just did a tune up but couldn't tighten on plug because his socket wouldn't fit? How'd you do the other 3? Anyway I tightened down and it still was missing, same cylinder it felt like. I pulled the plug wire off and it had a hole in it and was grounding out the the head intermittently. He had a spare cap and wire set in the trunk so I changed it with the car running. Gotta love 2 minute fixes!
Knockoff Crew member #0001
ae86-20v-black
Postby ae86-20v-black » Thu May 02, 2013 9:02 am
KonaTrueno723 wrote:^^^Man that must've been an "OH' :shock: SH*T" moment! But seriously,route them suckers away
i have accel universal wires from a v8 in my 20v microtech lt10 and individual coils. one of the cables jump and got stuck in the last 3 and 4 trotel but that every day hustle in my life....
Esenpai
Postby Esenpai » Sat May 04, 2013 10:45 pm
Installed new wheel bearings and fixed my alignment and changed my camber a bit. feels like its gliding now ^__^
oil change and installation of a project mu oil drain plug to come.
carbd7age
Postby carbd7age » Mon May 06, 2013 7:17 am
Today I found out my Mikunis are the smaller 40 size instead of 44, like I was told. So big ups to the previous owner. See I was debating between these and a set of Weber 45's cuz I need the bigguns. Oh well, no wonder the flange gaskets don't match up!
Also I drunk-ordered 10 Land Cruiser wheel studs, they're 10mm longer than stock. I might use em, I might sell em at a loss lol.
Ryusei_Date
Postby Ryusei_Date » Wed May 08, 2013 8:36 pm
I dusted some sucker in a Mustang on the way home today, thank god I live on a mountain pass XD That guy just didn't keep up in the corners, it felt great. Man I shouldn't get so aggravated when people tailgate me and flash at me, guess I'll let this one slide~ It's kinda sad how everyone bashes the 4-AC, it may only have 90 horsepower, but it's enough to take out a 300 something horsepower Mustang from the 90's! It's a good engine, I'd like to cram 4-AGE power out of it it if possible instead of the hassle of an engine swap, it's a cool little engine~ :mrgreen:
my car: 1986 Toyota AE86 coupe
grappletech
Postby grappletech » Wed May 08, 2013 8:55 pm
popped three tires. yes,three. got a flatbed to take her home. she will now sit for 9-12 months while I go to Afghanistan
87 GTS Coupe Super Duper Clean
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell (waiting on a 20v or BEAMS to come cheaply. hell maybe even a 4agze?!)
AE86LIFE
Postby AE86LIFE » Thu May 09, 2013 12:17 am
drive it.
Billy_Andrea
Postby Billy_Andrea » Sun May 12, 2013 6:17 pm
Finished mounting my dry sump oil tank
Scrapped the old tank mount as it wasn't to my liking. Cosmetically it was rough but functionally it was OK. It want everything with the swap to look as though a quality team put it together ( or at least as close as possible ) even if it means it takes 6 times longer than it should, which it already has... and the standard engine is still in the car !! This will take forever...
I had a local machine shop water jet two identical plates that fit the bottom of the tank. One alloy one which will be welded to the tank and one steel plate which I used to make the car to tank bracket. I welded nuts to each of the four perimeter holes to make the tank install an easier job.
Plate partially turned into bracket:
I drilled the spare wheel well where needed and installed nut serts to make removal / reinstall easy.
My favourite part of the whole thing are these bolts. Titanium 7mm BBS Bentley wheel bolts I rescued from a scrap wheel.
The most important thing to me with this engine was for nobody to be able to tell that there was anything different about the car until you hear it run. The choice of oil tank and bracket was carefully considered when buying and making. Voila ! Who can tell ?
My bulldog Riley said thank god he's finished. I'm tired and it's time to go home....
AE86LIFE
Postby AE86LIFE » Sat May 18, 2013 9:40 am
I casted the wagon with a magic spell today!
SolidSTI
Postby SolidSTI » Tue May 21, 2013 6:40 pm
Replaced the starter and got a nice rash on both forearms from the previous owners heatwrap.
http://TruFactsRacing.com
JDMwhiteboy
Postby JDMwhiteboy » Wed May 22, 2013 10:49 am
New spark plugs and a MSD blaster 2 coil. Still intermittent miss when under load. Next up wires next paycheck
Forum whore
ae86-20v-black
Postby ae86-20v-black » Wed May 22, 2013 12:46 pm
get wet in the raind becausa i dont have a/c and was rainin like hell!!!!!!!!!! i love my toyota
Ryusei_Date
Postby Ryusei_Date » Wed May 22, 2013 5:02 pm
got my heater control valve in, so now my defogger and heater actually work well now instead of half assed air blowing in my face! XD Too bad Summer's just around the corner...
carbd7age
Postby carbd7age » Mon May 27, 2013 5:18 pm
Almost finished my e-brake, I need a black seat knob. And I made a shifter cover out of sheet metal, then wrapped it in 3M carbon fiber vinyl.
MisterJerk
Postby MisterJerk » Tue May 28, 2013 6:18 am
I bent all 8 intake valves when my timing belt decided to eat the rubber gasket on the timing cover, got towed, since I was bwaaaah on some back roads on Sunday night.
Monday, ripped the head off and pulled all the intake valves and threw in a set out of another head. Didn't lap them in or anything. Cleaned it all up and put it back together in time to bbq. to top it all off, i got an illegal exhaust ticket on the test drive. OOHH YYEEAAHH! lol
SidekickChuck
Postby SidekickChuck » Tue May 28, 2013 8:44 am
Took a nice spirited stroll around the Rose Bowl and up and down some curvy roads for a few hours. Really made me want to get some hotter cams... (currently 256/264)
2001 Carbon Black e39 M5
chemtrails
Postby chemtrails » Thu Jun 06, 2013 2:27 pm
EJ86 wrote:I installed my 3rd vent cup holder (Seiwa W648), hopefully this one lasts:
(Hold you drinks or you air freshener or fold it in to hold your phone of packs of cigs)
where can i get one of these cup holders?
Failure to follow these instructions can result in death, serious injury, or equipment damage.
EJ86
Postby EJ86 » Fri Jun 07, 2013 12:46 am
I got it @ a local japanese store here in vegas...
Billy_Andrea
Postby Billy_Andrea » Fri Jun 07, 2013 9:37 pm
Mounted my tires.
Couldn't pass up a deal on a set of Good Year intermediates with almost no wear. Love the thread pattern. Not sure about the painted letters but will leave them on for now.
Compared to a Lambo rear tyre:
Autonerd
Postby Autonerd » Mon Jun 10, 2013 4:16 pm
SolidSTI wrote:Replaced the starter and got a nice rash on both forearms from the previous owners heatwrap.
quicktip: apply masking tape to the length of your arm and remove. glass particles will come out of your skin with the tape. repeat as needed ;)
BlackStar
Postby BlackStar » Tue Jun 11, 2013 6:38 pm
broke the threads on my intake. :oops: I drove it yesterrday too!
FrankP
Postby FrankP » Wed Jun 12, 2013 12:30 am
BlackStar wrote:broke the threads on my intake. :oops: I drove it yesterrday too!
*slowmotion running* Blllaaaaaaaccckkkkkkkkkkk sstttttttaaaaaaaaaaaaarrrrrrrrrrrrrrrrrrrrrrrr
FC_13
Postby FC_13 » Thu Jun 13, 2013 2:28 am
Simple Green'd my privacy cover...well, Round 1 anyways..gonna need a few more scrubbings.
Ryusei_Date
Postby Ryusei_Date » Sat Jun 15, 2013 8:34 pm
My dad was a poo and misaligned my headlight, so I fixed that today. All these boring petty things with me, I need some cash for new suspension or something to get more oomph out of my Hachi...
carbd7age
Postby carbd7age » Sun Jun 16, 2013 4:27 am
Finally put my tires on my SSR's. I did as much as o could with the wheels, they were in really rough shape when I got them. I can't wait to put them on!
carbd7age
Postby carbd7age » Thu Jul 04, 2013 12:12 pm
This thread should be updated a hundred times a day, everybody has to mess with their car, they're old Toyotas for crying out loud lolzzzz. Today I finished my fuel lines, friggin AN lines are a pain but whatever. I tried to check for leaks: battery is dead. I had to push it outside and jump from my Camry. Only leak was from a fitting that was hardly finger tight, oops. That's why we second check stuff! Then I relocated my OCC to the corner in front of the wiper motor, it looks cleaner I reckon. Then I gutted a very broke GTS gauge cluster so I can fill it with some AutoMeter gauges.
sqznby
Postby sqznby » Thu Jul 04, 2013 4:21 pm
Billy_Andrea wrote:Mounted my tires.
Wow, they some pretty nice wheels.
What are they? Specs to please?
Thank You
I have been driving mine around. Its funny, my car runs and drives rather well for a 30 year old car. Besides my valves leaking an my muffler hangin on by a coulpe of coat hangers, hah. Those of which will be replaced with new ones with the new parts waiting to be installed. I'll be doing my back half of the exhaust this weekend, I hope, hah.
sqznby
Postby sqznby » Sat Jul 06, 2013 9:54 am
I made this
as a temporary fix to put this on. I was only able to put the tail section of this exhaust on due to receiving a crap header from a pretty well known guy.
I am in the process of re-building it because of the terrible quality and craftsmanship on his behalf.
instead of this thing hangin off the back, hah
Esenpai
Postby Esenpai » Sat Jul 06, 2013 1:00 pm
MisterJerk wrote:I bent all 8 intake valves when my timing belt decided to eat the rubber gasket on the timing cover, got towed, since I was bwaaaah on some back roads on Sunday night.
do you have a machined block or head? or are you running higher duration cams? because unless you have a blacktop (which would have 12 intake valves) your engine should be non-interference....
Return to “Fun Talk”
