Setting pinion angle.
				The Bloody Panda
I'm about to install a one piece driveshaft into my 86 and I'm curious about the best places to check the angles.  I figure the flange at the rear end where the driveshaft mounts is obviously a good place to check the rear pinion angle.  However, I'm still debating about where to check the front/engine/trans angle.  I guess if I remove my driveshaft and spill a little transmission fluid I could check from right inside the cup on the end of the T50 where the driveshaft yoke goes in, perhaps this is the only good place to check it.  I'm thinking a more convenient place that could be just as good is my T3 crank pulley since I assume that it is flat and should give me the same angle reading.  Any advice is greatly appreciated.
						Re: Setting pinion angle.
1986 Corolla GT-S
1974 Corolla Deluxe Sedan
1983 Corolla Sedan
1987 Corolla GT-S
1984 Corolla SR5
1979 Corolla Liftback
http://www.natsukashigarage.com
http://www.facebook.com/natsukashigarage
1983 Corolla Sedan
1987 Corolla GT-S
1984 Corolla SR5
