Could this be a bad caliper?
I've checked for any leaks on the hoses, and they seem fine
It has a new brake booster
I checked my pads, and they are pretty messed up from one side...will update pics later
It sounds exactly the same as when a truck usually brakes and makes that long a$$ whinning noise. But this is only when braking slow
Whinning noise when braking
- EJ86
Re: Whinning noise when braking
Check your anti-rattling clips on the calipers...
EJ86 wrote:Check your anti-rattling clips on the calipers...
I did, still makes the same dumb sound...someone told me that it is wheel bearing? but if it were the wheel bearing then it should sound very differently?
No, bearings never whine when braking.
What does 'pretty messed up from one side' mean"
One pad worn more then the other because of a sticky piston or slide, or left to right side of the car?
Brake pad noise, try the goop that parts places sell, taper the pad, clean & smooth the pads backing plate where it contacts the caliper & those clips, piece of gasket paper/shoe box between the piston & pad.
allencr wrote:No, bearings never whine when braking.
Here is the brake pads..
I'd try putting a taper on the leading & trailing edge of those pads & see if that helps. Are you runnin drilled/slotted rotors miswuevos?
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
87 GTS Coupe
is the bottom one worn unevenly? looks like it, i bet the caliper slider thing is bent or frozen. when changing your brake pads, its a good idea to lube the bolts and stuff that allow the caliper to slide on the carrier.
KonaTrueno723 wrote:I'd try putting a taper on the leading & trailing edge of those pads & see if that helps. Are you runnin drilled/slotted rotors miswuevos?
konaTrueno723. No I am running solid discs
MisterJerk. I resent the calipers back to the company and told them they were defect, gladly they responded and told me it is going to take a week and half . I guess its worth the try,
I have tried lubing the bolts, put the shims, the clips, and nothing...
Will get back to you guys when I get them back
USE THEM!!!!
Get them stinking hot, then come back & whine about it!
