HKS 5AGE stroker crank (40mm rod journal) w/ Molnar 40/20 rods
You get what you see - HKS stroker crankshaft, and a set of 40/20 Molnar connecting rods to fit the 40 mm rod journal HKS crankshaft. Crank has been checked carefully - magged, and checked for straight.
email me, respond to this post, send me pm.
Price is $2100.00 OBO
Re: HKS 5AGE stroker crank (40mm rod journal) w/ Molnar 40/20 rods
can thiis fit for HH red top block?custom pistons?
I have a set of the origial HKS pistons for this crank that I have no plans to use, if that piques anyone's interest...
IG: unltd_86
aemo86 wrote:can thiis fit for HH red top block?custom pistons?
Yes - if you are asking if this will fit a smallport 4A block
all "A" cranks fit all "A" blocks as the main bearings are the same.
oldeskewltoy wrote:aemo86 wrote:can thiis fit for HH red top block?custom pistons?
kinda rushed to answer.... a 7A crank will fit the 4A journals, but it is too big to rotate - so you can't really fit "any" "A" crank into any "A" block. The HKS stroker crank does need some block modifications to work in a 4A block. the inside base of the cylinder walls @ the bottom may need to be ground down so the rods can pass - not uncommon when fitting an 83mm stroker crank into a 4A block
Bump............ or best offer
You couldn't take my offer. Work is real slow, offer would be real low.
One shot, one kill.
Bump $1800.....
bump... still available...
also available w/o the rods for $1400
bump......
800? and did you ship international
Driverone wrote:800? and did you ship international
too cheap... I do ship internationally at your expense
For some reason i cant pm you. For how much you would let it go?
Driverone wrote:For some reason i cant pm you. For how much you would let it go?
check your messages....
I figured out that i cant pm you because im not to active here sry. Probably both.
Driverone wrote:I figured out that i cant pm you because im not to active here sry. Probably both.
send me an email oldeskewltoy @ yahoo
Sry. Something happend in the familie. And i cant afford it anymore at the moment.
