TRD Multi-ECU programming software floppies
Toyoloog
Postby Toyoloog » Fri Feb 08, 2019 1:17 am
As per title I'm after another set of floppies as mine are so aged that the magnetic coating let go and therefore ruined the floppies...
Part number:
80901-SP001 for the 3.5" disks, or
80901-SP002 for the 5¼" disks.
Each part number is 2 floppies, a program disk and a data disk. Either number will be fine, heck I'll even take a good floppy image from the 2 disks. They don't have to be originals.
(For those not aware, these are floppies with software to program the TRD multi-ECU and is only for the NEC PC98 computers. They won't run on any IBM compatible machine, unless used in an emulator) If interested I can post the manual here as well but it's all in Japanese so might want some translation...
Coffee is what makes civilized life possible in these demanding times...
Re: TRD Multi-ECU programming software floppies
Postby oldeskewltoy » Fri Feb 08, 2019 7:03 am
would like to see the manual
Toyoloog
Postby Toyoloog » Fri Feb 08, 2019 9:03 am
Sure, I'll take a scan of the pages tomorrow.
Davegt27
Postby Davegt27 » Mon Feb 25, 2019 2:03 am
Interesting
Can you give the floppies To one of those companies that recover data?
Davegt27 Code One Racing
Toyoloog
Postby Toyoloog » Wed Aug 21, 2019 11:04 pm
Tried that but they don't accept floppies any longer over here. Even with my kryoflux it did not work, seems the magnetic medium is coming off and ruined both floppies unfortunately. My only hope is that Toyota / TRD might have a backup available somewhere. At least I now got a NEC PC95 to run the software on :D
Return to “Want to BUY (seeking sellers)”
