- Large items will require a quote or identified as pick-up only.
- DM me for PayPal info (send as gift or help pay fee), questions, or additional pics.
Instagram: ssgt_ackers
text me 530 949 72three0
- I can ship small items during the week. Large items will be quoted and shipped over the weekend.
**Sacramento, CA 95833**
- Pick-up preferred.
4A-GE 16v GT-S
- 4A-GE 16v GT-S oil pan baffle - $50 shipped
SOLD! - 4A-GE 16v GT-S throttle body - $50 shipped
SOLD! - 4A-GE 16v GT-S TVIS plate - $20 shipped
SOLD! - 4A-GE 16v GT-S spark plug cover - $20 shipped
SOLD! - 4A-GE 16v GT-S fuel filter w/ bracket and soft line (hard line removed after pic). 5 mins of use – Like new. - $20 shipped
- 4A-GE 16v GT-S cam cover rubber gasket - $15 shipped
- 4A-GE 16v GT-S fuel rail - $30 shipped
- 4A-GE 16v GT-S bluetop injectors, 23250-34030, 2.4 ohm, 210cc - $50 shipped
- 4A-GE 16v GT-S cam backing plate $50 shipped
SOLD! - 4A-GE 16v GT-S IACV - $55 shipped
- 4A-GE 16v GT-S water pump $75 shipped
SOLD! - 4A-GE 16v GT-S AFM setup - $200 shipped
- 4A-GE 16v GT-S 8.84-5.85 US, 89661-12090, 175600-0011, ECU - $75 shipped
- 4A-GE 16v GT-S bottom radiator hose - $15 shipped
SOLD! - 4A-GE 16v GT-S T50 OEM shifter - $70 shipped
- 4A-GE 16v GT-S shift knob - $35 shipped
- 4A-GE 16v GT-S T50 driveshaft - $160 (requires shipping quote)
AE86 GT-S
- AE86 GT-S OEM 4-links - $90 shipped
- AE86 GT-S rear shock dust covers - $15 shipped
- AE86 GT-S spring cushions - $25 shipped
- AE86 GT-S crossmember - $150 (requires shipping quote)
- AE86 GT-S crossmember bolts - $30 shipped
SOLD! - AE86 GT-S front fender liners - $60 shipped
- AE86 GT-S hatch tail lights. One tail light is painted with Super Autobacs smoked paint - $140 shipped
4A-GE 16v AW11
- 4A-GE 16v AW11 (88-92) redtop largeport fuel rail, 250cc green injectors, pulsation damper, and FPR - $110 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport cam covers - $80 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport TVIS plate - $20 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport waterline piping - $40 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport ECU, 89661-17020, 175600-0040, M/T, 85-85 US - $75 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport distributor cover - $15 shipped
* Tried to keep it together with black bumper bondo. The repaired side is hidden when covering the distributor.
4A-GE 16v
- 4A-GE 16v Magnecor R-100 Racing ignition cables 10mm silicone. - $85 shipped
- 4A-GE 16v/20v heavy-duty sprung pressure plate - from a shop in Vista. - $90 shipped
- 4A-GE 16v short ram air intake w/ AEM dry flow filter (used on JDM MAP setup) - $40 shipped
*How it looked fitted...
- 4A-GE 16v 7mm "Suppression Cable" ignition cables - $20 shipped
- 4A-GE 16v EGR Vacuum Modulator, vacuum switch valve, ECT sensor, CT sensor, and water line housing - $50 shipped
4A-GE 20v
- 4A-GE Blacktop 20v oil dipstick - $25 shipped
- 4A-GE Blacktop 20v water pump - $75 shipped
- 4A-GE Blacktop 20v engine oil pump screen pick-up tube - $30 shipped
- 4A-GE Blacktop 20v FWD heat shield - $15 shipped
SOLD! - 4A-GE Blacktop 20v OEM clutch, flywheel, and pressure plate - $150 shipped
- 4A-GE Blacktop 20v OEM trumpets x6 - $30 shipped / $8 each shipped
- 4A-GE Blacktop 20v intake camshaft - $150 shipped
- 4A-GE Blacktop 20v VVT intake pulley - $250 shipped
- 4A-GE Blacktop 20v exhaust pulley - $40 shipped
- 4A-GE Blacktop 20v exhaust camshaft - $150 shipped
- 4A-GE Blacktop 20v distributor - $80 shipped
- 4A-GE Blacktop 20v water outlet pipe - $20 shipped
- 4A-GE Blacktop 20v water inlet housing - $30 shipped
- 4A-GE Blacktop 20v No. 4 timing belt cover plate - $20 shipped
- 4A-GE Blacktop 20v No. 5 camshaft bearing cap - $20 shipped
- 4A-GE Blacktop 20v ISCV - $125 shipped
- 4A-GE Blacktop 20v custom airbox RWD- $120 shipped
AE86
- AE86 stainless steel braided brake lines - $60 shipped
- AE86 TRD oil cap - $25 shipped
- AE86 rear view mirror cover - $10 shipped
- AE86 clutch release bearing fork - $40 shipped
- AE86 clutch release hub and bearing - $50 shipped
- AE86 clutch release bearing - $25 shipped
- AE86 exhaust flanges - $10 each shipped
- AE86 OEM front lower control arms - $110 shipped
AE86 SR-5
- AE86 SR-5 steering wheel - $40 shipped
- AE86 SR-5 wheels - $60 (requires shipping quote)
- AE86 SR-5 wheel cover - $15 shipped
7A-FE
- 7AFE water pump - $40 shipped
MA46
MA46 Celica Supra rear end parts:
- MA46 OEM 4-link trailing arms - $100 shipped
- MA46 E-brake cable - $30 shipped
- MA46 7.5" Open Differential 3.73 - $175 shipped
- MA46 sway bar w/ end links - $80 shipped
- MA46 whiteline rear springs w/ insulators - $100 shipped
- MA46 14mm trailing arm bolts. Missing one nut and washer - $25 shipped
