IS300 radiator w/ fan
orange advan
A larger radiator from an IS300 with ford taurus 2 speed fan. This is larger than the OEM corolla radiator, but this will fit between the frame rails. Custom mounts will be required. This was going to go on the turbo setup, but never got around to installing. The fan is two speeds and it does move alot of air. For most applications the 1st speed will be more than you'll need, unless you really have potent power plant or like doing track day in las vegas in the middle of july. The setup would probably be beneficial the to a high hp engine or a v8 setup. Asking 140 obo. Located in cerritos ca. thanks alex email resuper3 at hotmail.com
