4AGZE on engine stand
Toyota8
Postby Toyota8 » Sun Mar 13, 2016 4:56 pm
Might be a stupid question, but I want to put my 4AGZE on an engine stand. Do you use the transmission bolts?
Re: 4AGZE on engine stand
Postby jondee86 » Sun Mar 13, 2016 6:57 pm
Depending on the type of stand, transmission bolts probably won't be long enough.
I had to buy some longer bolts and some heavy steel washers. Get the same thread
as the trans bolts... M12 x 1.25 (metric fine). I bought them 100mm long measured
from under the head, but 95mm would have been OK... needed to use quite a few
washers :). That was to suit a standard China made stand... you will need to check
how long the bolts need to be for your stand.
gotzoom?
Postby gotzoom? » Mon Mar 14, 2016 8:11 am
USDM bumper bolts work great. I shim with a stack of washers to fit my stand.
Postby oldeskewltoy » Mon Mar 14, 2016 8:20 am
If you have trailing arm bolts (the sizes that bolt to the axle) those are perfect length....
matt dunn
Postby matt dunn » Wed Mar 23, 2016 3:26 am
I had a set of spacers and bolts made for mine so I can put it on the stand with the flywheel on and still turn it.
Couldn't find the right things off the shelf.
hachipirate
Postby hachipirate » Sun Mar 27, 2016 11:10 am
Cylinder head bolts work like a charm too. Maybe a few spaces and viola.
