inputs for Megasquirt
Respeckmejulie
Postby Respeckmejulie » Sat Jun 20, 2015 11:57 am
Hey guys,
I searched and didn't find an answer to this question...
can i run the megasquirt (or any standalone, for that matter) without a DLI? using a crank trigger wheel and EDIS?
if i have a DLI, do i need a crank trigger wheel?
i'm building a 4A for my starlet, coil-on-plug.
thanks in advance!
Joel
My toyota collection: ''82 KP61, '87 AW11
Evo_lucian
Re: inputs for Megasquirt
Postby Evo_lucian » Sat Jun 20, 2015 6:11 pm
Yes you can run MS and most standalones off a crank trigger
Yes Megasquirt 2 , micro squirt and MS3 will work with DLI
Ratranger
Postby Ratranger » Sun Jun 28, 2015 8:41 pm
Megasquirt is easy, it will need to be modded to run COP. And if you want sequential you'll need a can signal as well as crank.
I'm currently running ms2 v3 with EDIS. Extremely simple to set up. Properly set up you don't need the edis controller for COP. What makes the biggest difference is version of ms and smart or dumb coils.
4age bigport in a 73 spitfire
ae86drftr
Postby ae86drftr » Wed Jul 01, 2015 10:42 pm
+1 for the Megasquirt! I have one myself on another engine (4G63) and it is amazing!!!
burdickjp
Postby burdickjp » Thu Jul 02, 2015 12:45 pm
Megasquirt is a family of ECUs. There are several versions with different capabilities.
Saying "will megasquirt do this" is like saying "will enkeis fit my car?".
The answer is, it depends on the model.
So what would you like to accomplish and what megasquirt are you looking at?
Sent from my XT1045 using Tapatalk
Pursuing the ideal
