Apexi hybrid intercooler: Used in good condition...measurements are shown in the picture....will fit ae86 with some mechanical massaging...to big for my setup so won't be using it...$250 Plus shipping
1JZ 380cc injectors, a must for any modified 20v...cleaned and balanced, was my spare set so haven't used since servicing: $150 set of 4 shipped ( only have one set other was sold already)
Omori Gauges, all are in great working condition, some have a few nicks here and there please look at pictures...price will reflect condition: Like New Electrical 45mm EGT with new probe $100 shipped (reads in Fahrenheit), 52mm White face Volts $75 shipped, 52mm White face Vacuum $75 shipped, 10k 52mm RPM Tach (very rare this size) with mounting stand $150 shipped, Stack mechanical water temp 63mm $75 shipped
OEM 20v alt bracket with custom tensioner modified to be used with rwd engine mount brackets : $45 shipped
Misc parts for sale ( brake master, visors, vacuum block SOLD) everything else hit me up for price.
S2000 Gauge cluster with pig tails,yellow box speed calibrator( requires speed sensor) and fuel level calibrator. Was working in my car swapping to a different setup...u will need to get a bezel from JSP or I will give whoever purchases this my JSP bezel once I get it back from being molded for a blank carbon one. $300 Shipped u won't find these clusters alone for that much with pig tails anywhere. If you want water temp and oil temp or pressure to work you will have to find a way to make that work...i didn't hook that up because i had individual gauges for that.
Custom Saikuo Michi 10an duel port catch can..can be vented to atmosphere or recirculated, drain on bottom..$95 shipped ....this was custom made for 135 dollars and it's a 10 week wait due to popularity and the fact that they are hand made if buy one direct..I switched to a duel can setup for boosted applications so selling this off
Oversized underdrive alternator pulley...works well if you have a smaller crank pulley which makes the alternator spin faster...$45 shipped (its the black pulley pictures just shows the size compared to stock size)
