5zigen header
Re: 5zigen header
Depends on what trim level you have. Do you have a GT-S or SR-5?
Second, what model is the header for?
Come back and tell a little bit more about what you have and what you're looking at.
Re: 5zigen header
It a 86 corolla gts hatch and I will find out what is the spec on the header.
Re: 5zigen header
It should fit as the 5zigen website says that it is for the AE86 and that is for the 4AGE. This means that it can only be 16v and that it should fit all 4AGE Corollas.
Someone, correct me if I am wrong, but I think that you should just go ahead and get the headers.
Re: 5zigen header
Unless they are only for RHD cars like most headers available from Japan.
Re: 5zigen header
jdm86gtz wrote:Unless they are only for RHD cars like most headers available from Japan.
Checked again and the header is for the same side as a US 4AG.
Re: 5zigen header
FYI most - if not all - Japanese market rwd 4age manifolds won't fit a left hand drive vehicle. Lhd models have a steering rack in the way of the exhaust and rhd doesn't. If the manufacturer doesn't specify that it will fit lhd assume it won't.
Re: 5zigen header
Deuce Cam wrote:FYI the vast majority of Japanese market rwd 4age manifolds won't fit a left hand drive vehicle. Lhd models have a steering rack in the way that rhd models don't have to deal with. If the manufacturer doesn't specify that it will fit lhd assume it won't.
That's helpful to know.
@ultradx: Do you really need the 5zigen header specifically? Why don't you try another search, man?
Re: 5zigen header
Thanks for the useful information, I will try to locate a vibrant header. I was hoping somebody had experience with it. the header is $830 shipped.
Re: 5zigen header
You will not find a vibrant header new. Power craft japan makes a LHD header.
If you are at the 800 dollar range for a header and you are looking for quality, you might as well save up the rest and get a JSP.
