sr20 to ae86 swap..
yelahachi84
sr20 to ae86 swap..
Postby yelahachi84 » Sat Feb 08, 2014 4:00 pm
just doing research and hoping to hear anyones advice on doing this swap, much appreciated!
what kind of diff? driveline?
and any other headaches commonly involved with this project.
lemme know! :?:
Lapdance
Re: sr20 to ae86 swap..
Postby Lapdance » Sat Feb 08, 2014 4:45 pm
google.
Postby MisterJerk » Sun Feb 09, 2014 6:16 am
buy a 240sx
redroku87
Postby redroku87 » Sun Feb 09, 2014 9:57 am
MisterJerk wrote:buy a 240sx
+1.
TheOxyMorin
Postby TheOxyMorin » Sun Feb 09, 2014 1:02 pm
+2
HingaSPL
Postby HingaSPL » Sun Feb 09, 2014 4:21 pm
+4, or try ClubSR20, this is Club4AG ;)
iamalexreece
Postby iamalexreece » Tue May 06, 2014 6:17 pm
yelahachi84 wrote:just doing research and hoping to hear anyones advice on doing this swap, much appreciated!
lemme know! :?:
You aren't going to find a whole lot of info here on c4ag for the sr20 swap. Lots of good people here with good info on the chassis and 4ag powerplant. Doing a swap like the sr20 (or KA as I'm doing) you have to split your time between here and S-Chassis forums. These guys have the expertise on the body and the s-chassis guys have the engine knowledge
here is a good thread on Zilvia for the sr20 swap http://zilvia.net/f/showthread.php?t=410133 lots of good info in there. If you or anyone else is considering the swap that thread is a great starting point.
marley4us
Postby marley4us » Fri May 16, 2014 10:08 pm
Ignor the haters. THough if you search there is a bunch of info on here and Zilvia. If toyota made a better power plant that could slap in easy everyone would use it, but the sr20det a good swap for bigger power.
biggest problem is dealing with the wiring and the downpipes clearance of the steering rack. Rearend u can keep the GTS if its built and ur not modding or turning up the boost on the sr20det... but they why even put that motor in. SO if your going over 220hp I would swap to a MA46/47 rearend or a ford 8.8, and you will need a custom driveshaft made to fit your motor and rearend.
1994 4runner (The truck)
4bangerpower
Postby 4bangerpower » Mon Jun 23, 2014 10:49 pm
X2 on the ford 8.8" as they are plentiful, lots of aftermarket parts & gear ratio options and you just have to cut about 3" off of the drivers side tube, weld it back together and run a passenger side axle in it. When they are shortened and run a passenger side axle in both sides the rear end is about 1" wider than the stock rear end.
