Ae86 Cluster Conversions! Usdm, Jdm Digital & Jdm Analog
The Robot Cow
Postby The Robot Cow » Mon Feb 03, 2014 1:33 pm
Hey there, I'm trying to put together a source for myself(and you guys) on how to rewire your harness for a jdm analog cluster since it's almost impossible to find a source that has this info. I will update this as i go along. Any help is welcome!
*Edit*
Since i'm going from my digital cluster to a Jdm analog i'll add the info on how my cluster is wired
Last edited by The Robot Cow on Fri Feb 07, 2014 11:12 am, edited 1 time in total.
1985 Corolla Gts Coupe
The Robot Cow
Re: JDM analog cluster conversion
Postby The Robot Cow » Mon Feb 03, 2014 10:30 pm
I'm using this archived topic as my basis of the Jdm Analog information
http://forums.club4ag.com/zerothread?id=48519
After completing the Jdm Analog wiring i'm assuming the 2 plugs should look like this
The white plug on the left
The blue plug on the right
And one more picture showing both plugs
Here's a list that I've made using Shannon's old pictures of how the wires are arranged.
Updated with more info!
JDM Analog Cluster
Left White Plug
1:Green with black stripe & brown dot-Turn Signal switch Terminal TL
2:Green with yellow stripe & brown dot-Turn Signal switch Termial TR
3:Yellow with red stripe-Fuel Sender gauge
4:Red with black Stripe-Brake Fluid warning/Parking brake
5:BLANK
6:Blue with white stripe-DOME fuse
7:Red with green stripe & blue dot-Efi Computer
8:Red with white stripe-Door Courtesy Switch
9:Yellow with blue stripe-Fuel Level warning
10:White with black stripe and pink dot-Ground
11:BLANK
12:BLANK
13:BLANK
14:BLANK
Right Blue Plug
1:Red with blue stripe-Gauge fuse
2:Black with brown dot-Ignition Coil
3:Black brown stripe-Ignition Fuse
4:Yellow with red dot-Charge Fuse
5:Brown with black dot-Ground
6:Red with green stripe-Dimmer Switch Terminal HU
7:BLANK
8:Red-Efi Computer
9:Yellow with black stripe-Oil Pressure
10:BLANK
11:Yellow with green stripe-Water temp
12:Brown with black dot & white stripe-Ground
13:Black with blue stripe & brown dot-Tail Fuse
14:Green with red dot-Rheostat or Ground
Digital Cluster
*Will include info later*
USDM
Left
1:blank
2:TAIL fuse
3:Rheostat or Ground
4:water temp sender gauge
5:gauge fuse
6:brake fluid lvl warning/parke brake switch
7:efi cpu
8:oil pressure sender gauge
9:ign fuse
10:charge fuse
11:blank
12:dimmer switch terminal HU
13:blank
14:blank
Right
15:dizzy(ignition coil)
16:ground
17:blank(chime)
18:cruise control cpu(efi cpu)
19:ground
20:DOME fuse
21:door courtesy switch
22:seat belt warning
23:blank(hazard lights)
24:fuel level warning
25:fuel sender gauge
26:ground
27:turn signal switch terminal TL
28:Turn signal switch terminal TR
Last edited by The Robot Cow on Fri Feb 07, 2014 11:16 am, edited 3 times in total.
The Robot Cow
Postby The Robot Cow » Tue Feb 04, 2014 12:57 am
What throws me off is the use of 2 Efi computer wires on the jdm/edm. Is there just 2 efi wires? On the USDM repair manual the 2nd efi computer is listed as the Cruise Control hmm...
morgan
Postby morgan » Tue Feb 04, 2014 7:08 am
i have a few pages of notes from a friend who did this, look like I need to dig my old camera out, I know I have pics of the pages. might be on the old forum, have you searched there?
choyr
Re: Ae86 Cluster Conversions! Usdm, Jdm Digital & Jdm Analog
Postby choyr » Thu Aug 21, 2014 5:03 am
are there still differences of digital clusters? USDM abd EUDM? How to know the differences?
strmrdr23
Postby strmrdr23 » Tue May 02, 2017 3:48 pm
The Robot Cow wrote:I'm using this archived topic as my basis of the Jdm Analog information
JDM Analog Cluster
Left White Plug
5:BLANK
11:BLANK
12:BLANK
13:BLANK
14:BLANK
Right Blue Plug
7:BLANK
8:Red-Efi Computer
10:BLANK
Digital Cluster
USDM
Left
1:blank
2:TAIL fuse
5:gauge fuse
7:efi cpu
9:ign fuse
10:charge fuse
11:blank
13:blank
14:blank
Right
16:ground
17:blank(chime)
19:ground
20:DOME fuse
26:ground
sorry to bump this from the dead but the link to the old walk through appears to have died. anybody have a walk through for wiring analog jdm cluster to usdm ae86? i have an SK engineering cluster i may try to tackle installing (i'm super color blind so this will be interesting).
Users browsing this forum: yabaiani and 1 guest
