Velocity stack size/length ?
Hi guy
Im seeking help on the velocity stack in market for blacktop..
Im intending to use a custom air for the itb on my blacktop.
So my question is so u need to use a velocity stack? Or just use a air box with a cone filter and stackless?
What stack length available on market? And where to source them.
Thank guy
I may want to use the shortest length stack for air box.
Thank guy
Re: Velocity stack size/length ?
You want these bad boys...
IMEC trumpets... I don't know where to get them, but they are around.
Those look jdm stuff
Any body?
T3 stack are too long and SQ i dont know what is the shortest length they do
Any body?
Lucky I got time on my hands... here ya go...
http://www.tokyoseven.com/T7/product_info.php?cPath=28_123_124&products_id=1697
Oh wow...
U so great...
Appreciated man
U so great...
Appreciated man
phanist wrote:SQ i dont know what is the shortest length they do
Have you contacted him? Or visited his website? 'cause he has a list of the lengths he offers.
http://s-86.com/velocity_stacks.php
Why do you wanting uber-short stacks?
Pursuing the ideal
Planing on using it with a custom air box
phanist wrote:Planing on using it with a custom air box
Anything else done to the engine? Shorter stacks will push the usable harmonics induction up in the rev range. Usually out of the usable range of an unmodified engine. Longer stacks will, conversely, bring it down.
This guy offers some advice on intake harmonic tuning. He cites Bill Sherwood's page.
http://www.my-acoustic.com/Car/intake_e ... intake.htm
Pursuing the ideal
I rebuilt it with pon cam
Toda oil gear and ported pump.
Ferrea valve and spring kit
That a out it for internal .. Of course new seal gasket etc..
I intend to install this noby booth throttle induction air box.
phanist wrote:I rebuilt it with pon cam
Excellent choice of parts. What are you planning on doing with the car? That'll decide a lot about where you want power, which will determine what length of stacks you should run.
The really good thing is that stacks aren't hard to change. You can always keep a few sets around for specific applications.
Pursuing the ideal
Lol
Some drifting if posible and
But lot of dailly
I do gripping too.
I do have carrilo rod in there as well
But lot of dailly
I do gripping too.
phanist wrote:Lol
But lot of dailly
I do gripping too.
What are you wanting as an acceptable redline? Understand that the higher it is, the faster the wear parts of your engine will wear.
I like power in the middle of the rev range. Corner apex RPM. That's where the 4A needs help. That's where you'll find yourself on the street or autocross. My understanding is that drifting is all top end. I'd say track time is somewhere between the two.
So, if you're wanting a car for drifting; find a good RPM between redline and where the RPMs drop to when shifting at redline. Use this as your target power RPM. This makes sure that, as long as you're in the right gear, you are making power. For autocross and daily, the RPM drop point might be a good choice.
The good news is that you can try a few different options, even keep a few on hand for drift days, daily-ing, etc.
Pursuing the ideal
Oh about the rev limit.
I dont know what my engine current rev limit it yet... I haven even try red line...
- BattleGarage_RS
For what it's worth, SQ Engineering makes stacks as short as 43mm for silvertop, 50mm for blacktop. Quite a bit less money than the SP-Tec stacks listed above.
-Grant
-Grant
phanist wrote:Oh about the rev limit.
What engine management system are you running? Just the stock ECU?
Pursuing the ideal
Grant
I think the 50mm is a bit too long for the air box.. I did check out battlegarage website.
Burkdickjp
Yes i am using the stock ecu...
Burkdickjp
- BattleGarage_RS
I actually used stacks that were about 40mm or so in my own car, with a factory air box. Although some report power gains with short stacks in the factory box, I actually realized a loss. This could be because I converted the air inlet from the "front" of the box, to feeding from the side, though. Maybe there was unequal feeding of the cylinders.
At any rate I moved to Pipercross (sorry I wrote ITG earlier, that is incorrect) filter over long stacks and never looked back. Your goals may be different than mine (reduced noise or something).
Good luck!
Grant
Good luck!
Grant
Last edited by BattleGarage_RS on Wed Dec 11, 2013 11:38 pm, edited 1 time in total.
Grant so your setup are longer stack meaning 110mm on itg filter?
I end up order those 30mm from SP-tec
- BattleGarage_RS
If you want to use long stacks you may order 100mm ST or BT stacks but you use a pipercross filter.
110mm stacks have a larger bell mouth, mainly for appearance, but they will not work behind any filter.
To be clear, 100mm stacks ONLY work with a pipercross adapter plate and a pipercross filter =)
The ITG unit will only clear 70mm or shorter stacks, like T3, etc.
