gts vs sr5 bellhousing. difference visually?
How can I tell from a picture which is a gts and which is a sr5 before I buy. Please advise. Thanks.
Re: gts vs sr5 bellhousing. difference visually?
If you had the bellhousing installed in a car then, GT-S will have the clutch fork hole on the passenger side. SR-5 will have it on the driver side.
I only have a pix of it off and looking at inside. The clutch fork is on the left and that lump ball looking thing is on the right.
If you are standing at the engine end and looking inside... and the hole where the
fork pokes thru the side of the bellhousing is on your left, then you are a 4AGE. If you
are standing at the gearbox end, the clutch fork and the slave cylinder will be on your
right (passenger side). Unless the bellhousing is upside down.....
Post a pic, we will be able to tell you for sure.
GTS, 4age t50 tranny, at least bellhousing.
Works for me! Thanks.
