hi guy
i have question. when doing the swap for the ae86 20v swap. you need to use a 4 wires 02 sensor..
but which one?. i mean is it the air fuel ratio sensor or the oxygen sensor?
thank
20v blacktop 02 sensor
Re: 20v blacktop 02 sensor
Part 89465-19685 (SENSOR, OXYGEN) was found on the following models:
Date range Model Frames/Options
06/1991-05/2002 TOYOTA COROLLA AE10*,CE10*,EE10*
05/1995-07/2000 TOYOTA COROLLA AE11*,CE11*,EE111
05/1995-07/2000 TOYOTA SPRINTER AE11*,CE11*,EE111
06/1991-07/1998 TOYOTA LVN AE10*
05/1995-07/2000 TOYOTA LEVIN, TRUENO AE11*
08/1995-06/2002 TOYOTA SPRINTER CARIB AE11*
©2013 ToyoDIY
©2013 ToyoDIY
jondee
is that a toyota part number?
i try go to toyota dealer and ask for 1998 corolla 02 sensor and they tell me which one..lol and ask me for a vin number
im looking at this denso on amazon
http://www.amazon.com/Denso-234-4162-Ox ... +02+sensor
would this work... ?
As far as I know the AE111 was not sold in the US, nor any car fitted with
the 20V BT engine. So the sensors are JDM and US dealers will not have the
O2 sensor listed as a standard part. It will be special order from Japan,
and $$$. I have read that some people have had success using sensors from
other vehicles. I think the Denso one may work, but you need to check that
the plug and flange fittings are correct for your engine.
- alavelle12
if you have blacktop you can use a 3sge o2 sensor from an mr2
alavelle12 wrote:if you have blacktop you can use a 3sge o2 sensor from an mr2
In which case the pics from this link might be useful
http://www.mr2australia.com/mr2play/tm.aspx?m=94348
does it matter where i mount the sensor to? i using neither trd 4-1 header or the copy cat of it.. where is the best place to mount this sensor to? i see some guuy mount it on the header by #4 cylinder ... or should i mount it after all port merge at down pipe>?
phanist wrote:... or should i mount it after all port merge at down pipe?
^this. OBS sells an O2 sensor for a sw20 mr2(3SGTE) on ebay for $60, works fine. i have it running in my 20v swap
- alavelle12
morgan wrote:^this. OBS sells an O2 sensor for a sw20 mr2(3SGTE) on ebay for $60, works fine. i have it running in my 20v swap
I purchased the same one for my 20v swap, have yet to install everything though. And I believe he meant OBX
yeah, typo. OBX
http://www.ebay.com/itm/OBX-OXYGEN-O2-S ... b2&vxp=mtr
are those plug and play MORGAN?
LOL
LOL
You need to modify the connector slightly or use old O2 sensor pigtail and repin it.
shoot thank man
its easy, dont be detered by either. to mod the plug, just take teh white "rib" out from the inside(clip it off the rest of the white plastic piece) and sand down the outer edges.
