Window Moldings
Posted: Sun Sep 08, 2013 9:00 pm
by truenoboy
Is there anywhere that sells replacement window moldings for our cars?
Re: Window Moldings
Posted: Mon Sep 09, 2013 8:36 am
by morgan
no for aftermarket.
TOR Parts is your best bet, bnib from dealer, cant get better than that
Re: Window Moldings
Posted: Mon Sep 09, 2013 9:00 am
by TORPARTS
we can get oem if needed...let us know
Re: Window Moldings
Posted: Mon Sep 09, 2013 7:16 pm
by truenoboy
Aftermarket or OEM, doesn't matter. Torparts, I sent you and email.
Re: Window Moldings
Posted: Thu Sep 19, 2013 6:01 am
by truenoboy
Still looking.
Re: Window Moldings
Posted: Sat Sep 21, 2013 8:00 pm
by NateTheRipper
Torparts is the best. got my speedo gear and tail light seals from them highly recommend.
Re: Window Moldings
Posted: Sun Sep 22, 2013 2:35 am
by allencr
Discontinued from the factory?
In some post somewhere, they tried that liquid plastic stuff, that coating that tool handles are dipped in to.
I thought about trying to get some thick wall heat shrink tubing.
Re: Window Moldings
Posted: Tue Sep 24, 2013 2:49 pm
by MisterJerk
i think plastidip would work to do the mouldings. the hardpart would be getting all the old shiz off
Re: Window Moldings
Posted: Thu Sep 26, 2013 2:27 pm
by Illegal_Garage
No replacement parts
But you can recondition
I use steel wool then wash them
Then lacquer thinner
Then paint in the booth with trim black reduced 50/50
Max
Re: Window Moldings
Posted: Fri Sep 27, 2013 2:20 pm
by krammit the frog
Save them and do as said above, recondition. If you take your time, they turn out great. No reason to toss a perfectly good set in the already dwindling marketplace.
Re: Window Moldings
Posted: Fri Sep 27, 2013 5:46 pm
by Illegal_Garage
a quart of trim black is pretty cheap too
I think about $20
1 quart of trim black can do all the trims and black bumper parts on maybe 2 or 3 GTS
Max
