AE86 TRD Header
RLZ
AE86 TRD Header
Postby RLZ » Sun Sep 08, 2013 1:17 am
Hi guys, just got a 4-1 header for my 86 16v blue top, been told its TRD, But how can you tell it's a real TRD?
Tora
Re: AE86 TRD Header
Postby Tora » Sun Sep 08, 2013 3:09 am
Does it fit? TRD
But seriously, OBX makes a TRD 4-1 knockoff. It's sturdy but not the most carefully made piece, and it shows. (I have one.) How to tell if yours is real, besides any identifying marks on it... you already bought it, right?
carbd7age
Re: AE86 TRD Header
Postby carbd7age » Sun Sep 08, 2013 7:04 am
Pics? If you paid more than 200 bucks, either it's real or you got ripped off on a fake. 100 bucks it less, it's OBX or you are one lucky dude that just stole a TRD header lol.
Knockoff Crew member #0001
RLZ
Re: AE86 TRD Header
Postby RLZ » Sun Sep 08, 2013 11:35 am
Tora wrote:Does it fit? TRD
It's not polished, the paint just like silver or grey, it's 2 pieces. I didn't install it yet so not sure about the fitment. And the magnet sticks it.
RLZ
Re: AE86 TRD Header
Postby RLZ » Sun Sep 08, 2013 11:38 am
carbd7age wrote:Pics? If you paid more than 200 bucks, either it's real or you got ripped off on a fake. 100 bucks it less, it's OBX or you are one lucky dude that just stole a TRD header lol.
I will post pics later today, I paid $260 shipped. It does looks like my old one but it has mounting for heat shield and the old one doesn't !
carbd7age
Re: AE86 TRD Header
Postby carbd7age » Sun Sep 08, 2013 1:19 pm
My OBX has mounting points for a heat shield.
RLZ
Re: AE86 TRD Header
Postby RLZ » Sun Sep 08, 2013 1:50 pm
carbd7age wrote:My OBX has mounting points for a heat shield.
On my old TRD it doesn't has mounting points, OBX are polished, but this one is not, it's grey color.
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Sun Sep 08, 2013 5:25 pm
The egr bung is at the correct angle on the trd manifold.
Collector casting is noticeably better.
Trd doesn't hit the chassis.
Trd dp tucks nicely under frame rail.
carbd7age
Re: AE86 TRD Header
Postby carbd7age » Sun Sep 08, 2013 5:28 pm
Not all OBX are polished. They are available with a plain coating, mine is.
Tora
Re: AE86 TRD Header
Postby Tora » Sun Sep 08, 2013 6:54 pm
Deuce Cam wrote:The egr bung is at the correct angle on the trd manifold.
This x1000
RLZ
Re: AE86 TRD Header
Postby RLZ » Sun Sep 08, 2013 8:37 pm
Here are some pics i took today, it has heat wrap before as you can see
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Mon Sep 09, 2013 7:40 am
That is trd :mrgreen:
RLZ
Re: AE86 TRD Header
Postby RLZ » Mon Sep 09, 2013 11:12 am
Deuce Cam wrote:That is trd :mrgreen:
Phew~ how can you tell?
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Mon Sep 09, 2013 1:41 pm
Mainly by the collector and angle of the egr bung. Compare with a picture of the obx manifold on ebay and you'll see what I mean.
Also, come to think of it I don't think obx has oem style flanges at the manifold-to-dp connection like trd. I think they're flat flanges.
RLZ
Re: AE86 TRD Header
Postby RLZ » Mon Sep 09, 2013 5:39 pm
Deuce Cam wrote:Mainly by the collector and angle of the egr bung. Compare with a picture of the obx manifold on ebay and you'll see what I mean.
Oh i see, thanks man! So what gasket should i use between the manifold and down pipe?
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Tue Sep 10, 2013 7:52 am
oem
RLZ
Re: AE86 TRD Header
Postby RLZ » Tue Sep 10, 2013 11:12 am
Deuce Cam wrote:oem
Do you mean the stock one like a "O" ring?
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Tue Sep 10, 2013 11:26 am
Yeah you need the oem o-ring/donut gaskets that are used on the stock cat because they use the same style flanges.
If someone else has found something better to use please let me know. The oem gaskets are a pita to center.
AZNWOKZ
Re: AE86 TRD Header
Postby AZNWOKZ » Wed Sep 11, 2013 10:14 am
down pipe to header + the down pipe to CAT covertor use the O-ring gasket.
a nice way to keep the O-ring center is to use a small film of high Temp silicone. That's all.
RLZ
Re: AE86 TRD Header
Postby RLZ » Wed Sep 11, 2013 4:56 pm
AZNWOKZ wrote:down pipe to header + the down pipe to CAT covertor use the O-ring gasket.
What about I replace the cat with the test pipe? I don't think test pipes has the flange to fit the O ring gasket right?
Deuce Cam
Re: AE86 TRD Header
Postby Deuce Cam » Thu Sep 12, 2013 12:39 pm
My trd dp has a flat flange where it connects to the cat, unlike the donut flange where it connects to the manifold. Most test pipes have flat flanges. You'll have to compare them to be sure and go from there.
rumsawatti
Re: AE86 TRD Header
Postby rumsawatti » Thu Feb 27, 2014 7:30 am
Real or not real?
milchmann
Re: AE86 TRD Header
Postby milchmann » Thu Feb 27, 2014 8:29 am
The collector is wrong on this one. The TRD collector is a formed collector, where as what is on the right* is just wrapped metal. The TRD also has much nicer tig welds that join the collector and runners where the fake has sloppy running welds probably from a mig welder. Do you see the dent on the top of the fake collector? That is from it hitting the chassis. The TRD collector clears the chassis.
rumsawatti
Re: AE86 TRD Header
Postby rumsawatti » Thu Feb 27, 2014 9:05 am
Thanks for the info. "The TRD collector is a formed collector, where as what is on the left is just wrapped metal." dont really understand this part...do you mean that they are both fake?
milchmann
Re: AE86 TRD Header
Postby milchmann » Thu Feb 27, 2014 12:40 pm
Ha! No, I apparently just never learned my left from my right. I meant to say "where as what is on the right is just wrapped metal". I changed the original post so that it does not trip anyone else up.
This is a formed collector.
http://www.summitracing.com/parts/pte-h7672?seid=srese1&gclid=CKXLqaWU7bwCFRQV7AodVkIAfw
The one on the left is a formed collector, and is in fact a TRD header. If you really examine the two, you can also tell that the knock off on the 'right' has much more aggressive mandrel bends in it ... which is something you do not want.
solo2go1
Re: AE86 TRD Header
Postby solo2go1 » Thu Feb 27, 2014 1:05 pm
The OBX header hits the steering shaft as well. PITA. :evil:
ra40
Re: AE86 TRD Header
Postby ra40 » Sat Mar 01, 2014 8:40 pm
I had a real trd header on when i bought my car. Unfortunately I didn't know it was real. When I had a new exhaust made I cut the flange off the header and welded the exhaust right onto it like an idiot.
