Fitting RWD 16v alternator bracket onto 20v
canyon_carvers
Postby canyon_carvers » Fri Aug 30, 2013 7:48 am
I read through a few forums & trying to gather information about swapping 4age 20v into AE86. It seem straight forward but I haven't found anything covering on "installing RWD 16v alternator bracket onto 4age 20v." Some say you can use the RWD alternator bracket and that was it.. They didn't mention anything about the bracket not clearing due to the Timing belt tensioner in the way... What do I need to do to properly fit the RWD 16v alternator bracket onto a 4age 20v? Here are some pictures...
ga_goosh
Re: Fitting RWD 16v alternator bracket onto 20v
Postby ga_goosh » Fri Aug 30, 2013 2:13 pm
you have 2 options. 1 get a grinder and make it fit (I would grind on the alt bracket and not the engine) or 2 get a 16v or silver top oil pump and tensioner
I <3 my AE86
4AG Manual
AE86 FSM
MisterJerk
Postby MisterJerk » Fri Aug 30, 2013 4:23 pm
I ground a notch in the bracket to make it fit my 16/20 conversion. I later changed to the 16v/ST oil pump/tensioner setup and kept the same bracketry
canyon_carvers
Postby canyon_carvers » Fri Aug 30, 2013 5:23 pm
Thank you both for the information. I'll start doing some grinding.
