Bent panhard bar + video
4agewin
Postby 4agewin » Wed Aug 28, 2013 2:07 pm
Just picked an ae86 from norcal and wanted to get some input from you guys, the panhard is bent previous owner hit a curb and hit the rear passenger wheel. car is totally driveable, not weird noises from the diff, welll..other than a
ga_goosh
Re: Bent panhard bar
Postby ga_goosh » Wed Aug 28, 2013 2:12 pm
to tell you the truth that car was probably lowwered at one point previous to you owning it. that is a cheap trick to fix the axle position when you cut or install drop springs. your springs in your pics dont look stock either plus if the previous owner hit the pass side the panhard bar wouldnt have bent like that since the panhard mounts to the chassis on the pass side and to the axle on the drivers side. a new panhard would be all you need to fix axle position the 4 links are used for pinion angle
I <3 my AE86
4AG Manual
AE86 FSM
carbd7age
Postby carbd7age » Wed Aug 28, 2013 6:12 pm
Dang bent like a boss! I have a stock panhard if you want it, but you got a new one from T3 right?
Knockoff Crew member #0001
ae86xy
Postby ae86xy » Wed Aug 28, 2013 10:51 pm
Now go get yourself a new used panhard bar
4agewin
Postby 4agewin » Thu Aug 29, 2013 8:07 am
got one from t3, anyone have an idea on how to adjust this things? Do i have to jack up the car on the axle or on the chassis?
Postby Deuce Cam » Thu Aug 29, 2013 8:32 am
I recommend installing it with the car on the ground and the suspension loaded, but have a jack handy under the diff. to make lining up both mounting points easier. I started by adjusting the bar to stock length off the car then installed it. Next I shortened the bar a little using a wrench on the turnbuckle adjuster until it's loose enough to turn with just my fingers (when the turnbuckle becomes easy to turn that indicates the rear is close to center). Then fix the bars length at the middle of the adjusters 'loose' range. Finally get an alignment.
4agewin
Postby 4agewin » Thu Aug 29, 2013 1:19 pm
Hssh
miswuevos
Re: Bent panhard bar + video
Postby miswuevos » Fri Aug 30, 2013 1:43 pm
video?
SidewaysGts
Postby SidewaysGts » Sat Aug 31, 2013 3:53 am
I read your initial post and was going to type up a word-of-caution post
Then you posted that video. Yup.
carbd7age
Postby carbd7age » Sat Aug 31, 2013 8:08 pm
Holy crap what the feff are you doing under the car with it running like that!?!?!?/!! Also, you have a bend axle, sorry.
ae86xy
Postby ae86xy » Sat Aug 31, 2013 9:32 pm
While your at it check the axle housing for straightness I've seen hiusing get bent too.
BKH808
Postby BKH808 » Sat Aug 31, 2013 11:28 pm
Sounds just like what ive done in the past, hit curb on driver side, bent panhard bar, and bent axle. IIRC weir can straighten the axle out!
4agewin
Postby 4agewin » Tue Sep 03, 2013 9:10 pm
BKH808 wrote:Sounds just like what ive done in the past, hit curb on driver side, bent panhard bar, and bent axle. IIRC weir can straighten the axle out!
Did you do it with them?
Users browsing this forum: MSN [Bot] and 10 guests
