Levin/Trueno Rad. Support and sub-assy the same?
silvertwotones
Postby silvertwotones » Fri Aug 16, 2013 1:16 pm
Hi, for anyone who has made the front end swap, is the radiator support (53216-12927) the same for both Levins and Trueno front ends?
Additionally, are the stamped metal pieces behind the headlights the same, the sub assemblies? (53211-12220 and 53212-12200)?
Thanks
ga_goosh
Re: Levin/Trueno Rad. Support and sub-assy the same?
Postby ga_goosh » Fri Aug 16, 2013 1:21 pm
if you are asking if the levin front will bolt to the trueno rad support the answer is yes. im not sure if they are the same tho
I <3 my AE86
4AG Manual
AE86 FSM
Postby Deuce Cam » Fri Aug 16, 2013 1:25 pm
The upper/lower radiator supports are the same. The stamped headlight backing is 99% the the same, only difference is the oem fixed headlight front aka levin has 2 small headlight bracket mounts welded on. Luckily they can be purchased new from Toyota japan and are supplied with self tapping screws and retention nuts. You just need to drill 6 small holes and screw them on if converting from pop up lights to fixed lights.
silvertwotones
Postby silvertwotones » Fri Aug 16, 2013 2:10 pm
Thanks guys!
