I do not know if they all use the same fittings between brands, but specifically I have the Greddy and Omori brands. I am seeking the bolt and thread type they use for the output senders to oil pressure gauges etc. Also there is a big threaded hole for a plug Greddy uses which I need to plug as well. Problem is, I went to my local hardware store, and none of their plugs and/or bolts have the correct threading to fit. Is it a special compression thread or something that is hard to come by?
Pic showing the big gold plug that I need to fill as well as the oil cooler lines I need to plug up but cant find a bolt that fits:
Same goes for the Omori Unit. I need to find bolts that fit where the copper colored ones in the pic are located:
