Key stuck in the ignition
Like the title says my key stuck I can start/shut off the ae86 but the key wont come off I push the black square next to it still nothing it only comes out half way
Re: Key stuck in the ignition
spray some wd40 in the tumblr and jiggle?
Did spray wd40 and jiggle it with vise grip, just comes out halfway.
Do you guys think by disassembling the cylinder key would get the key out?
try to put super glue on the key stub and reatach it to the old piece. now carefully try to pull it out with the button pushed. it may release it enough to get it out or at least to try to get it with pliers
im not sure on this one but if you can get the ignition cylinder out i think you might be able to push it out through the other end with a paper clip. if not take the cylinder to a lock smith to fish it out
Thanks guys, got it out took the whole cylinder soak with wd40 left it for 2hr. Push it out the other end and came out, tried the spare key now its all good.
Wish i could taken a pix but didnt have time
