My 4ac is missing/sputtering?
Posted: Mon Jun 17, 2013 3:25 pm
Not sure which word to exactly discribe it by. (6/9/13) After my last fail, I had my carb rebuilt and tuned, and ask the re-builders to set it up to have a better chance to pass smog. Unfortunately, I think they overly leaned out the carb. With the engine running, it sputters slightly, and the fuel in the bowl is below the bottom mark. When i rev the engine over 2k rpms, it beginnings to sputter more, and the revs decrease. I checked the plugs, they are in the good range, and maybe going to the lean rnage.
I did some more work (6/17/13)
I still have my problem. I adjusted the carb's float, it is now between the bottom and top notches in the float bowel. At idle, it feels like it has a missfire, it doesn't feel smooth. Not really rough either, since according to the tach needle it is constant and strong. Revving the engine, from 1k to 2k, ti revs fine. 2K and above(though mainly between 2k and 2.5k) it does the same miss tendency. For example, say if i rev the engine to 2.5k rpm, and hold it, the rpms will fluctuate, go down, then trying to go back up to maintain. even if it does go back to 2.5rpms, it will still fluctuate.
The plugs are a year old. The rotors is maybe 6 months old. The rotors also shows no signs of damage, same with the rotors cap. I changed spark plug wires to the originals my car had, and noticed the missing worsened. The wires I am running currently I found in good 'looking' condition at the pick a part. it could be my problem. However, The car never ran like this before with the wires.
The only part that has changed in any way since when it was running fine till now was the carburetor rebuild. Either the wires'went bad(though unlikely) while the car was sitting, or I am looking at the work system. I also don't want to start throwing money at it till I have a good idea on where to focus.
Could it be the 91 grade fuel I am running in it? Before, I only used 87.
