AE86 GTS Brake Rotors and Pads
RLZ
Postby RLZ » Sat May 18, 2013 10:55 pm
Hi, I wanna replace the front and rear brake rotors,pads and lines on my 86 GTS. Want some good at both track and street but most for street tho. Looking to get slotted rotors and stainless lines. Dont really know what to go for, what brands? Any options?
mad_86
Re: AE86 GTS Brake Rotors and Pads
Postby mad_86 » Sun May 19, 2013 10:50 am
For ss brake line don't cheap out use goodridge as brakelines
Check out the shop sections there's a few shops that have what your looking for
GL
RLZ
Postby RLZ » Sun May 19, 2013 11:37 am
mad_86 wrote:For ss brake line don't cheap out use goodridge as brakelines
GL
Goodridge are around $150 a set, is that a fair price? seem expensive to me just few lines.
On the shop section i only found the 88rotors, i heard its not a good thing to go for.
Jacare
Postby Jacare » Sun May 19, 2013 6:42 pm
check tirerack, i know they had them for like 115-120. get some super blue or motul to finish the install.
im going to be running some Hawk HPS pads this summer, ss lines, n im not sure what rotors. gotta replace my booster first
RLZ
Postby RLZ » Sun May 19, 2013 7:31 pm
Jacare wrote:check tirerack, i know they had them for like 115-120. get some super blue or motul to finish the install.
Hawk HPS pads good for all seasons? I really need some rotors options, anyone?
What about this slotted rotors? http://brakeperformance.com/brake-rotor ... Rotors.php
Postby MisterJerk » Mon May 20, 2013 6:42 am
88 rotors has good stuff. good deals on slotted rotors and hawk pads.
RLZ
Postby RLZ » Mon May 20, 2013 9:13 am
MisterJerk wrote:88 rotors has good stuff. good deals on slotted rotors and hawk pads.
Are they works good? ppl say don't take 88rotors but I never try tho!
Postby MisterJerk » Mon May 20, 2013 10:46 am
I have had their rotors a couple times. they work well and last a while.
RLZ
Postby RLZ » Mon May 20, 2013 12:30 pm
MisterJerk wrote:I have had their rotors a couple times. they work well and last a while.
which set up you used?
mad_86
Postby mad_86 » Thu May 23, 2013 11:42 pm
Goodridge are a good quality made brake line
just like anything else theres always better/ higher quality lines
But for more $$$, defiantly compare prices before purchase
As for your brake & rotor needs you gotta find
What you need , ex.rotors Slotted ,drilled , vent &non-vented,
Nickel plated, non-nickel plated you should research there's
So many choices,
Hope it helps a bit, lol
