Length of rear brake soft lines?
Posted: Thu May 09, 2013 1:09 pm
by Rogue-AE95
I need to know the length of the rear soft lines, the one that leads to the axle and the two that run to the disc brakes. I bought a Techna-Fit set for an AE92 GT-S (# TOY-710) in order to have the correct fronts for my AE95, but the AE95 rear is more like an AE86. My AE95's rear soft lines (only two, leading to the rear axle) are about 12 inches long including the end fittings.
Looking at a Driftworks SS braided line set, assuming that image is showing the actual product, you guys have three rear soft lines. ToyoDIY seems to confirm this. One leading to the rear axle, and two on each side for the rear discs.
Only problem I have is that my two rear lines have a female fitting on each end, but your AE86 rear lines all seem to have a male and female on each end. I'll contact Techna-Fit later to see if they have something that will work, or if they can make me custom rear lines in exchange for my AE92 GT-S rear lines. Maybe I can buy a male to female connector and make it work that way with two of the AE86 rear lines... if they're long enough. But I'd prefer to have correct, single lines.
Re: Length of rear brake soft lines?
Posted: Mon May 13, 2013 4:52 am
by ga_goosh
I have some rear soft lines you can have for comparison if you want. they are still good and came from ebay but there is less then 2000 miles on them just cover shipping and they are yours. ill also give them a quick measure when i get home
