high rpm stumble issue.......stumped (blue top)
Posted: Tue May 07, 2013 5:27 pm
okay, so aquired this car in a trade, and really came out on top (5th ae86 =]) i got it for a steal, because it had sat since 2004-ish with almost a half of tank of gas. early 2013, the owner, started it up, and decided to try and drive it around..............
need i say more?
anyway, they attempted a new fuel pump, thought the sending unit was the pump port, seen that it wasnt and gave up. at this point they drained the 2001 fuel out of the tank, filled it with new fuel, and tried again........
no go.
so, i managed to get the car onto a trailer under its own power to bring it home. ive dropped the tank, poured in 2 gallons of alchohol, and a 5 lbs. bag of river rock, and shook, and shimmied, and slushed until my arms fell off. (works kinda like a washing agent against the rust pitts in the tank) so i removed all the river rock, followed thru with another alchohol flush of about 4 gallons to ensure it was rinsed thoroughly. i then allowed it to dry in the sun for about 2 days before re-installation.
i also, changed the fuel pump at this time, and installed a sending unit, since the original was no where to be found.
ive removed the old fuel filter and let about 1 gallon of fuel pump freely through the line to clean out any debris. upon removing the fuel filter, it was full of what looked like concrete dust. i found that the fuel line was kinked, right before the fuel filter. so using a small screwdriver, i drove it into the line, and opened up the kink, (like a swedge) to where a screw driver almost the same i.d. as the fuel line, passed freely through the kink.
installed a new fuel filter.
so, i start the car, let it warm, rev it a few times, etc. then proceed to test drive it. low rpm, great, mid rpm, great. if your above 6k rpm for longer than about a sec. the engine hesitates, and falls flat on its face till i let off the throttle. then it picks right back up for about another sec.
timing is spot on, car runs and revs really good (127k miles =]) i know these cars pretty damn well, but this.....this has me absolutely stumped. any insight? suggestions, etc?
need i say more?
no go.
