motor keeps breaking water pumps
hachiroku ae86
Postby hachiroku ae86 » Thu May 02, 2013 2:51 pm
so my motor has broken 2 water pumps recently the first i thought it was just on its way out so i didnt think anything about it.i just swapped it out for a new one and went for a drive and all was good then CLINK and my belt i just bought went flying off the side of the road. ill try to post pics later but what happen is the water pump pulley came off the pump with the mounting bracket off the pump it happened both times but the first time my whole pump blew up in to 7 pieces this time just the mounting point came off the pump rendering it useless and to top it all off it ruined my new radiator. has anyone had this happen before i am lost here any help will be appreciated :?
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
morgan
Re: motor keeps breaking water pumps
Postby morgan » Thu May 02, 2013 4:26 pm
Are you putting an ae86 clutch fan on a FWD water pump? They're not built to hold the fan, go e-fan or RWD pump.
My turd of an 86
20v swapped 86 write-up
OG UTOTMO
Postby OG UTOTMO » Thu May 02, 2013 8:57 pm
this happen to me i purchase a water pump they gave me a water pump thats meant for a 4ac which uses d same water pump as the 4age the only thing diff was that gts has a longer neck and when u install the pulley is not going 2 line up.
ga_goosh
Postby ga_goosh » Fri May 03, 2013 6:47 am
yup you have 2 options get a RWD pump or swap to efan.
OG UTOTMO wrote:this happen to me i purchase a water pump they gave me a water pump thats meant for a 4ac which uses d same water pump as the 4age the only thing diff was that gts has a longer neck and when u install the pulley is not going 2 line up.
you probably got one from an aw11 mr2 or a FWD corolla . the 4ac has the same part number as the 4ag
I <3 my AE86
4AG Manual
AE86 FSM
