So I've finally gotten to the point where I can put my engine into my car, but I need a throttle cable that will work with the swap. Can I use a GTS cable, or is there a similar one I can get that won't take six weeks to get to Canada? I've been googling it, but besides recommendations to get a KE70 cable (Not easy to source) I'm not coming up with good solutions.
Any recommendations?
20V to SR5 accelerator cable - Recommendations
1984 SR5-GTS 20V ST/BT coupe.
- Stance GR+ Coilovers
- Mishimoto Cooling
- T3 adjustable 4-bar, Panhard, traction brackets, tension rods
- T3 Short shift
- Manual rack conversion
- Blacktop electronics
- Mishimoto Cooling
- T3 Short shift
Re: 20V to SR5 accelerator cable - Recommendations
toyota tercel
There's five generations of the Tercel. Which one?
- Mishimoto Cooling
- T3 Short shift
- Mishimoto Cooling
- T3 Short shift
eary 90's tercel,,, go to jy and look under sum hoods,, you will see its much longer..........
I got mine off an 94 tercel
Did you route the cable normally as well?
- Mishimoto Cooling
- T3 Short shift
- Mishimoto Cooling
- T3 Short shift
Perfect, thanks for the tip.
- Mishimoto Cooling
- T3 Short shift
- Mishimoto Cooling
- T3 Short shift
