Front coilover spring
Posted: Thu Apr 11, 2013 6:58 pm
by RLZ
Hi, I need a stiffer springs on the front coilovers, does this fit?
http://www.ebay.com/itm/STANCE-Suspensi ... 43&vxp=mtr
Re: Front coilover spring
Posted: Mon Apr 15, 2013 11:10 pm
by RLZ
anyone?
Posted: Mon Apr 15, 2013 11:13 pm
by ronny
65mm is the size - depending on what perch ur using
Posted: Tue Apr 16, 2013 12:02 am
by RLZ
ronny wrote:65mm is the size - depending on what perch ur using
Should be the one from T3, so if T3 does it works? thanks!
Posted: Tue Apr 16, 2013 4:42 am
by ga_goosh
yes that will fit the perches from the ground control kit. i.d. is 2.5 inches and so is most coilover perches
Posted: Tue Apr 16, 2013 9:19 am
by RLZ
ga_goosh wrote:yes that will fit the perches from the ground control kit. i.d. is 2.5 inches and so is most coilover perches
do you think they are the same length? thanks!
Posted: Thu Apr 18, 2013 11:11 am
by ga_goosh
yei am running 8 inch springs on my coilovers you shouldnt have any issues with those springs
Posted: Thu Apr 18, 2013 3:34 pm
by RLZ
ga_goosh wrote:yei am running 8 inch springs on my coilovers you shouldnt have any issues with those springs
ok thanks a lot!
