7age clutch
ae86xy
7age clutch
Postby ae86xy » Thu Apr 04, 2013 11:56 pm
Just finished my full rebuild on the 7age months ago this is going on my 86 gts
My question is will my rwd clutch will work on a 7sfe flywheel or I would need to get a rwd 4ac flywheel in order to work.
mikeyee
Re: 7age clutch
Postby mikeyee » Fri Apr 05, 2013 3:07 am
any 200mm clutch oughta be fine if you're using stock 7afe flywheel (is 7sfe flywheel also 200mm?)
im currently looking for a lightweight flywheel for better response and have found some info regarding 7afe (6-bolt) being compatible with 4ac flywheels, and 4ac's being compatible with 3tc/2tc flywheels. and aftermarket is quite larger with the 3tc/2tc's... found one supplied with lightweight 3tc flywheels...
but just gonn settle with dropping my oem flywheel off at a machine shop and have them butcher it up for me and hopefully save some skrill over dropping 200+ for lightened 3tc flywheel that i found...
carbd7age
Re: 7age clutch
Postby carbd7age » Fri Apr 05, 2013 6:19 pm
I'm using a 4AC flywheel. A lot of 4AC guys have tried different 3TC flywheels and I can't say for sure if any ate successful. Hit up Max here on the forums, he can get em.
Knockoff Crew member #0001
ae86xy
Re: 7age clutch
Postby ae86xy » Fri Apr 05, 2013 7:02 pm
Are all 4ac flywheel 200mm?
carbd7age
Re: 7age clutch
Postby carbd7age » Sat Apr 06, 2013 4:10 am
Yes. Forgot to add I'm using an AE86 clutch.
mikeyee
Re: 7age clutch
Postby mikeyee » Sat Apr 06, 2013 2:37 pm
carbd7age wrote:I'm using a 4AC flywheel. A lot of 4AC guys have tried different 3TC flywheels and I can't say for sure if any ate successful. Hit up Max here on the forums, he can get em.
yep^
talked to max last night about lightweight flywheel options for the 7AGE. and he mentioned he has some 6-bolt 8lbs flywheels available for them. think he said pricing was like $200-300ish iirc. (i'll ask him about again today).
but I'm going to be picking one from him and run it.
ae86xy
Re: 7age clutch
Postby ae86xy » Sun Apr 07, 2013 3:58 pm
mikeyee wrote:any 200mm clutch oughta be fine if you're using stock 7afe flywheel (is 7sfe flywheel also 200mm?)
Yes I do have the stock 7 flywheel so your saying it would work with my 4age clutch
