Mind the "tofuness" of my question...
I might buy one if I can make it work in my car, but I don't know if the bracket is even available in the USDM harness or where to install it.
All help is appreciated!
Does the dingdong chime work on a USDM 86?
Re: Does the dingdong chime work on a USDM 86?
Some old car has them almost the same sounds but I'm not sure which cars, if you can find which car has it then just go to junk yard look for the car. My gf's Acura TSX has the dingdong sound when you forget to take the key out.
Yes, thanks but I'm not asking about that,
I already got a chime located for a reasonable price and I was wondering if I can make the JDM chime work on a USDM car
YoShImUrA wrote:Yes, thanks but I'm not asking about that,
Where did you get your chime? is it he JDM AE86 one? I think it can be done i think..
I haven't bought it yet, I'm about to...
can you make it work? yes
will it be easy... who knows but you ca most likely figure out a way to make it happen
Yeah, I figured. Thanks, NC Panda
I GOT A BIT OF NEW INFO!
I just bought the JDM chime and checked the part number in the system.
I have attached the graph with the part number (86640) in case anybody knows or recalls a loose bracket/plug/connection around there (behind the heater controls in the lower graph) that might fit the chime on our USDM cars.
Any help is appreciated!!
I want to do this to my 86 as well..cause that 1980's eeeeeeeeeeeeeeeee' chime is mentally effecting me big time! Please post results..thank you!
Or maybe I should just unplug it!
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
87 GTS Coupe
