The cable going from the battery neg to the ground: 4 gauge?
Posted: Tue Mar 26, 2013 10:27 am
by Turtle
Is it 4 gauge?
R
Re: The cable going from the battery neg to the ground: 4 ga
Posted: Tue Mar 26, 2013 11:23 am
by ga_goosh
Posted: Tue Mar 26, 2013 1:06 pm
by chemtrails
Posted: Wed Mar 27, 2013 9:30 am
by MisterJerk
8 gauge sounds about right for the grounds that go from battery to body and firewall to head.
Instead of buying a replacement toyota ground, I made my own with Automotive, stereo amplifier power wire, and copper connectors. They had 2 gauge on sale, so I got 5 ft, the connectors, shrink tubing, and some solder.
I made 3 grounds, battery to body, battery to coil, firewall to head and had a bunch left over.
for the connectors, instead of crimping. Held connector with vice grip, heated with a torch, melted solder in, then jammed the cable in.
Posted: Fri Mar 29, 2013 1:56 pm
by Turtle
MisterJerk wrote:8 gauge sounds about right for the grounds that go from battery to body and firewall to head.
Yep, in the process of upgrading the big 3, which is almost exactly what's listed above. Got some 4-gauge wire for half off at home depot, though if I were so inclined, I would have gotten wire with a higher strand count. Took a torch to secure the ring terminals with solder (which was really fun, btw, playing with fire.). I may add another for the head and the coil if I have extra parts. Stay tuned.
R
