Weber carburetor choke
Posted: Tue Mar 19, 2013 10:20 pm
by yangster
i have a question about hooking up my choke on my weber carb. how would u connnect it? the wire's on the old carb is way different so idk how i would hook it up. need some quick advice asap. i dont knoe wat to do so let me knoe.. thanks
Re: Weber carburetor choke
Posted: Wed Mar 20, 2013 2:44 am
by Hxckid213
yangster wrote:i have a question about hooking up my choke on my weber carb. how would u connnect it? the wire's on the old carb is way different so idk how i would hook it up. need some quick advice asap. i dont knoe wat to do so let me knoe.. thanks
you connect it where the stock would go maybe you need to splice it.
Posted: Wed Mar 20, 2013 10:04 am
by yangster
which wire do i connect? bcus the old one has a big green thing?
Posted: Wed Mar 20, 2013 1:20 pm
by KonaTrueno723
Green thing meaning a plug? Get a test probe to find a 12v + power (key on) in that green plug. Connect the choke to this power source.
Posted: Wed Mar 20, 2013 2:53 pm
by yangster
hey u got any pictures of wat u mean?
Posted: Wed Mar 20, 2013 5:37 pm
by KonaTrueno723
No I'm afraid not..do you still have the stock carb by any chance? There were a couple elec plug connections on the stock carb, do you remember disconnecting them? If you don't have the carb anymore, that's ok. Look at the pass fender well area.. These plug connections (female end) should all be there & still remained connected to the cars engine bay elec harness.. You can quickly identify them as round & green in color. You can get your 12v power source from one of these plugs to operate & run the choke on your weber. This12v power is also wired to the cars ignition (on & off) switched
Posted: Thu Mar 21, 2013 1:36 am
by Hxckid213
that green connector you need to cut the wire and hooked the weber coil wire to it. or like the other member said hook it up to a key on 12v.
Posted: Thu Mar 21, 2013 1:37 am
by Hxckid213
Hxckid213 wrote:that green connector you need to cut the wire and hooked the weber coil wire to it. or like the other member said hook it up to a key on 12v.
follow the wire from the coil to the green connector and cut it.
Posted: Thu Mar 21, 2013 7:26 am
by yangster
thanks guys but, do u guys know which wire exactly? I don't know which one would be the 12v wire.
Posted: Thu Mar 21, 2013 12:46 pm
by KonaTrueno723
yangster wrote:thanks guys but, do u guys know which wire exactly? I don't know which one would be the 12v wire.
An sr5 visited my shop this morn..yellow wire. Good luck!
Posted: Thu Mar 21, 2013 6:45 pm
by yangster
thanlks that really helps, I'll try it out
