Postby Red » Thu Mar 21, 2013 1:18 pm
"No chance" is why *no* exhaust line is ever taken into the cabin. Even if there was a one-way valve, or a suction venturi in the line, those devices can and do fail regularly, and the flow can reverse through them.
And that's the problem: There's just no safe way to run an exhaust fitting into the cabin. Even when the exhaust is totally outside the cabin, people manage to get killed by it. If you notice, any time the ignition is "on" even when the engine is off, the fan blows at a low speed. You cannot turn off the fan completely, no matter what you do. This was mandated as a safety requirement (I think in the 70s in the US) to bring in "fresh" air from the base of the windshield because the only way to keep exhaust out, is to pressurize the cabin with fresher air. And again, even with that annoying fan, people still find ways to get monoxide poisoning. Its no fun.
But on the bright side, at least you've got a readymade fitting to hook up a relief tube.<G>
-- Original owner, 1985 GT-S
