4age Flywheel Alignment-HELP Needed
Posted: Fri Mar 01, 2013 2:53 pm
by Omni86
so basicaly from scratch im instaling a flywheel with no alignment marks to work with on block/flywheel.
There are the 3 grooves in back.
Two holes through flywheel opposing each other.
At TDC where should I align my grooves/holes?
i'd really appreciate some advice to get past this thank you.
Re: 4age Flywheel Alignment-HELP Needed
Posted: Fri Mar 01, 2013 3:05 pm
by Omni86
So at tdc 3 holes are at top... Correct or 90 180 rotation?
Posted: Fri Mar 01, 2013 3:15 pm
by Omni86
3 grooves on backside to Top at TDC. MR2 guy at Lithia Toyota, Cheers.
Posted: Fri Mar 01, 2013 8:11 pm
by runkillerrabbit
wait it matters on how the fly wheel is put on?
Posted: Fri Mar 01, 2013 8:46 pm
by Omni86
Not a 100% on the 4a c/ge but some njuns it matters. I had nothing to go on so wanted to be sure.
Dealership mechanic said to set the three grooves on backside to tdc. This aligns the thru holes to each side roughly.
If you hold the flywheel in place and spin it you can feel a slight weight transition, being abit ocd I had to complusively find the finite balance. Should see me set piston to tdc lol.
Posted: Fri Mar 01, 2013 10:17 pm
by allencr
The flywheel is balanced by the factory, those holes are where weight was removed and mean nothing more then that.
Just for good work practice, position should be marked before removal even though it's unnecessary.
Any feeling of 'a slight weight transition' is only in your head.
Posted: Sat Mar 02, 2013 12:42 am
by LongGrain
does not matter, just bolt it on and go.
