4age Flywheel Alignment-HELP Needed
Omni86
Postby Omni86 » Fri Mar 01, 2013 2:53 pm
so basicaly from scratch im instaling a flywheel with no alignment marks to work with on block/flywheel.
There are the 3 grooves in back.
Two holes through flywheel opposing each other.
At TDC where should I align my grooves/holes?
i'd really appreciate some advice to get past this thank you.
Omni86
Re: 4age Flywheel Alignment-HELP Needed
Postby Omni86 » Fri Mar 01, 2013 3:05 pm
So at tdc 3 holes are at top... Correct or 90 180 rotation?
Omni86
Postby Omni86 » Fri Mar 01, 2013 3:15 pm
3 grooves on backside to Top at TDC. MR2 guy at Lithia Toyota, Cheers.
runkillerrabbit
Postby runkillerrabbit » Fri Mar 01, 2013 8:11 pm
wait it matters on how the fly wheel is put on?
FIDM fashion design
ITT tech electrical engineer
R2D2 build log
Omni86
Postby Omni86 » Fri Mar 01, 2013 8:46 pm
Not a 100% on the 4a c/ge but some njuns it matters. I had nothing to go on so wanted to be sure.
Dealership mechanic said to set the three grooves on backside to tdc. This aligns the thru holes to each side roughly.
If you hold the flywheel in place and spin it you can feel a slight weight transition, being abit ocd I had to complusively find the finite balance. Should see me set piston to tdc lol.
allencr
Postby allencr » Fri Mar 01, 2013 10:17 pm
The flywheel is balanced by the factory, those holes are where weight was removed and mean nothing more then that.
Just for good work practice, position should be marked before removal even though it's unnecessary.
Any feeling of 'a slight weight transition' is only in your head.
LongGrain
Postby LongGrain » Sat Mar 02, 2013 12:42 am
does not matter, just bolt it on and go.
