no light and won't start after gts swap
Posted: Thu Feb 28, 2013 10:48 pm
by mok167
As title says, I got those problems after the gts swap. I have replace all of the gts harness, pump, and fuel line.
Don't know what happen. Need help.
Thanks
Re: no light and won't start after gts swap
Posted: Fri Mar 01, 2013 8:20 am
by overspool
No light? What light?
Does it crank over? Does it do anything?
If it cranks, go rent a noid light set from you local auto parts store (oreilly, autozone). Check to see if your injectors are getting signal from the ECU. Go buy a spark tester, undo one of your plug wires, then connect the spark tester. See if you are getting spark. If you have both of those, make sure your timing is on. If it still isn't working, rent a fuel pressure gauge and plug it in line and see if the fuel pump is working.
